Helllo ,
The db Path modification in the advance general setting is’nt available with the version plex 1.20.1.3252-a78fef9a9.
Where is the setting who you can change de path of the db. Before it was in the advance general settings.
Thanks you
Helllo ,
Thanks you
That setting was removed due to security concerns. You can still move your Plex data directory by using the instructions here:
