.db-shm and .deb-wal on Unraid 6.9.2/PMS-Docker breaking
Server Version#: Version 1.24.2.4973
I will provide server logs if needed, but need to know which log so I can clear out personal data first.
I have the Plex Media Server Docker Docker Hub, that is running on Unraid 6.9.2.
The media plays great, GPU decoding/encoding works perfect, but every morning when I check the server, I can browse to it’s Local-IP:32400, and interact with Plex settings but the server doesn’t exist to make specific settings changes for this server.
I then go to:
/mnt/user/appdata/Plex-Media-Server/Library/Application Support/Plex Media Server/Plug-in Support/Databases
and delete the .db-shm and .deb-wal files and restart the server and everything is fine.
Media shows back up with all the proper names and posters without having to rescan.
I’m guessing I need to repair the database, but the guide is not made for Docker. I tried Linux, but those commands don’t do anything for the docker version.
Does anyone have proper commands for the docker container to fix this?
Or is this a bug that needs to be reported?
