Quick question on the transcoding logic between RasPlex and the server as things stand. As I understand it when decoding DD/DTS the RPi needs to do this in software, which causes a significant performance hit and can cause trouble playing 1080p with DTS.
Given that, would it be a better idea to get the Plex server to do the decoding if necessary instead. Eg.
- If RasPlex audio settings say we have 2.0 receiver which isn't DD/DTS capable, then request 2-channel PCM from the server
- If the RasPlex settings say we have a 5.1 receiver which is DD/DTS capable, then just pass through to the receiver with no transcoding
Is that something that's been considered? If it's a client-side change only I might be keen to give a hand implementing it (though I might need a few pointers first)...
