Server Version#: 1.13.7.5369-93c9f1259
Player Version#: N/A
I had a PMS deadlock happen around 9/8 15:37 EDT.
The PMS server was restarted with SEGV after being unresponsive for ~6 minutes.
PMS logs included.
/connections logs also included.
System info:
Linux Centos 7
12GB of mem
32 CPU - Intel® Xeon® CPU E5-2630 v4 @ 2.20GHz
Please let me know if any further information is need.
Thank You
System Info at the time of the deadlock:
Crash Report:
Sep 08, 2018 15:43:35.835 [0x7f50b5336700] INFO - Crash Uploader - Platform: linux-ubuntu-x86_64 (3.10.0-693.11.6.el7.x86_64 (#1 SMP Thu Jan 4 01:06:37 UTC 2018)) ServerUUID: 1a4bbb9f4c29a0125c69c390d74c8fe1ce7277b1 UserId: REMOVED Version: 1.13.7.5369-93c9f1259
Sep 08, 2018 15:43:35.835 [0x7f50bfdc8780] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Sep 08, 2018 15:43:37.740 [0x7f50bfdc8780] DEBUG - HTTP 200 response from POST https://crashreport.plexapp.com
Sep 08, 2018 15:43:37.740 [0x7f50bfdc8780] INFO - Successfully reported 4a1f85a5-6285-bafc-111918bc-7e0a6e35
Edit 9/8 8:20PM : Added system information.
Edit 9/11: removed logs
ChuckPa
September 9, 2018, 12:42am
2
Thank you for capturing and reporting so well with your OP.
I’ve already messaged the team member who specializes in deadlocks & crashes.
Please leave everything as is until he instructs otherwise. (probably tomorrow)
You are welcome. Anything I can do to make it even easier or any other metrics to capture, for the future, do not hesitate to let me know.
I have have created a few scripts to automating data collection. I do not mind adding more to it
Scripts I created incase someone else would like to capture the same information.
sa2000
September 9, 2018, 3:34pm
5
Thank you very much for all the work on getting the diagnostics. much appreciated.
This has now been referred to the development team
The problem started at 15:37:10 (after about 36 hours running)
@sa2000 Can I remove the log files? I would prefer not to leave them up longer than I need to.
sa2000
September 11, 2018, 4:14pm
8
Yes you can remove them - I have everything I need
@sa2000 does the latest Plex Media Server address this issue? I saw a fix for HDHomeRun tuners and was not sure if that applied.
sa2000
September 20, 2018, 5:21pm
10
I am afraid there isn’t a fix for this. It may not be straightforward - what is the frequency ?
Since the crash happened relatively quickly after the upgrade I downgraded back to 1.13.6.5339 but that version also has a memory leak when transcoding certain audio… High Memory Usage Transcoding 4K content . I was just asking since I saw mention of a crash. I was not sure if it was related.
sa2000
September 20, 2018, 6:31pm
12
I would not expect deadlocks to be frequent as they are to do with some specific timing conditions and I thought that the deadlock was not new in 1.13.7
The fix for the crash in the release note is for those in this forum topic Stability issues with 1.13.6.5339
sa2000
November 22, 2018, 2:17pm
13
Are you still getting the deadlocks seen here before?
The latest beta 1.14.0.5468 does address a deadlock but it is different from what was seen in your process dump.
I updated to the latest (1.14.0.5468-5a0183d2c). I have not experienced a deadlock since my OP. If it does occur in the near future I will update this post.
Thank you for following up.
system
Closed
February 24, 2019, 4:14pm
15
