Debian repo issue (armhf/Packages) - FIXED
Server Version#: 1.24.5.5173
Hit:1 http://phoscon.de/apt/deconz buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 https://downloads.plex.tv/repo/deb public InRelease [6,685 B]
Ign:4 https://downloads.plex.tv/repo/deb public/main armhf Packages
Get:4 https://downloads.plex.tv/repo/deb public/main armhf Packages [532 B]
Err:4 https://downloads.plex.tv/repo/deb public/main armhf Packages
  File has unexpected size (432 != 532). Mirror sync in progress? [IP: 104.18.12.47 443]
  Hashes of expected file:
   - Filesize:532 [weak]
   - SHA256:2c26a29dbd3bfd051a2964fef41f10882adf6df5e5f1d7ea6085f2cdef723b63
   - SHA1:26caa9d9434dc2d6c236b531bea0cf24d58b870c [weak]
   - MD5Sum:ab74cfc4d22a7ba5ba5047705129719a [weak]
  Release file created at: Wed, 01 Dec 2021 03:40:10 +0000
Hit:5 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists... Done
E: Failed to fetch https://downloads.plex.tv/repo/deb/dists/public/main/binary-armhf/Packages.xz  File has unexpected size (432 != 532). Mirror sync in progress? [IP: 104.18.12.47 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I have exact the same problem with this repo.
[chuck@lizum sources.list.d.2027]$ curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  3072  100  3072    0     0  31346      0 --:--:-- --:--:-- --:--:-- 31346
OK
[chuck@lizum sources.list.d.2028]$ sudo apt update
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://packages.microsoft.com/repos/code stable InRelease
Hit:7 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:8 http://ppa.launchpad.net/heyarje/makemkv-beta/ubuntu focal InRelease
Hit:9 https://linux.teamviewer.com/deb stable InRelease
Get:11 https://downloads.plex.tv/repo/deb public/main amd64 Packages [464 B]
Ign:12 https://mkvtoolnix.download/ubuntu focal InRelease
Hit:13 https://mkvtoolnix.download/ubuntu focal Release
Hit:10 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
Fetched 464 B in 2s (270 B/s)
Building dependency tree
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
[chuck@lizum sources.list.d.2029]$ sudo apt install plexmediaserver
The following NEW packages will be installed:
  plexmediaserver
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 87.0 MB of archives.
After this operation, 236 MB of additional disk space will be used.
Get:1 https://downloads.plex.tv/repo/deb public/main amd64 plexmediaserver amd64 1.24.5.5173-8dcc73a59 [87.0 MB]
Fetched 87.0 MB in 1s (73.5 MB/s)
Selecting previously unselected package plexmediaserver.
(Reading database ... 575809 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.24.5.5173-8dcc73a59_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.24.5.5173-8dcc73a59) ...
Setting up plexmediaserver (1.24.5.5173-8dcc73a59) ...
PlexMediaServer install: PlexMediaServer-1.24.5.5173-8dcc73a59 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install:   Installation Type:   Update
PlexMediaServer install:   Process Control:     systemd
PlexMediaServer install:   Plex User:           plex
PlexMediaServer install:   Plex Group:          plex
PlexMediaServer install:   Video Group:         render
PlexMediaServer install:   Metadata Dir:        /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install:   Temp Directory:      /tmp
PlexMediaServer install:   Lang Encoding:       en_US.UTF-8
PlexMediaServer install:   Intel i915 Hardware: Found
PlexMediaServer install:   Nvidia GPU card:     Not Found
PlexMediaServer install:   OpenCL:              Installed
PlexMediaServer install:   Beignet:             Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.24.5.5173-8dcc73a59 - Installation successful.  Errors: 0, Warnings: 0
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
[chuck@lizum sources.list.d.2030]$
I have notified the build team.
its fixed. thank you!
