Hello,
Ive been having a problem downloading the latest plex media server version from the official plex repository. Here is a snippet of the error I am getting when running an “apt update”
Err:5 https://downloads.plex.tv/repo/deb public/main amd64 Packages
File has unexpected size (1696 != 1772). Mirror sync in progress? [IP: 104.18.156.41 443]
https://downloads.plex.tv/repo/deb/dists/public/main/binary-amd64/Packages.xz does have a file size of 1696 bytes when downloaded.
However the repository’s InRelease file https://downloads.plex.tv/repo/deb/dists/public/InRelease is stating that the file should be 1772 bytes instead, hence the error. Could we get this issue corrected? Thank you!
Check your system please.
Cannot replicate here. (Eastern USA)
root@ubuntu:/etc/apt/sources.list.d# dpkg -l | grep -i plexmedia
ii plexmediaserver 1.21.3.4046-3c1c83ba4 amd64 Plex organizes all of your personal media so you can easily access and enjoy it.
root@ubuntu:/etc/apt/sources.list.d# apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 https://downloads.plex.tv/repo/deb public InRelease [6,685 B]
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:6 https://downloads.plex.tv/repo/deb public/main amd64 Packages [1,696 B]
Fetched 90.4 kB in 1s (123 kB/s)
Reading package lists... Done
root@ubuntu:/etc/apt/sources.list.d# apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
linux-headers-4.15.0-137 linux-headers-4.15.0-137-generic linux-image-4.15.0-137-generic linux-modules-4.15.0-137-generic
linux-modules-extra-4.15.0-137-generic
Use 'apt autoremove' to remove them.
The following packages will be upgraded:
plexmediaserver
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 86.8 MB of archives.
After this operation, 13.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://downloads.plex.tv/repo/deb public/main amd64 plexmediaserver amd64 1.22.3.4392-d7c624def [86.8 MB]
Fetched 86.8 MB in 1s (65.7 MB/s)
(Reading database ... 201006 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.22.3.4392-d7c624def_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.22.3.4392-d7c624def) over (1.21.3.4046-3c1c83ba4) ...
Setting up plexmediaserver (1.22.3.4392-d7c624def) ...
PlexMediaServer install: PlexMediaServer-1.22.3.4392-d7c624def - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Intel QSV Hardware: Not found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL library: Installed
PlexMediaServer install: Beignet package: Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.22.3.4392-d7c624def - Installation successful. Errors: 0, Warnings: 0
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for libc-bin (2.27-3ubuntu1.4) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Well it seems like the issue has resolved itself. Thank you for the reply and checking things out on your end.
I swear the InRelease file had a different size listed for Packages.xz. Well, at least it did yesterday and from the particular server I was downloading it from lol. I wasn’t just trusting the apt error message, I downloaded the files manually from a separate Windows 10 pc and verified the discrepancy.
I haven’t changed anything in my configuration and now everything is working. Giving me your geolocation was a helpful reminder if I needed to continue troubleshooting. I wasn’t thinking about different mirrors at the time, so I didn’t try any troubleshooting using that angle. Not sure how many exist, but downloads.plex.tv resolves to multiple different servers across the United States. I’m in the midwest and perhaps there was a temporary issue with a particular server there.
Thanks again!
