I like the new approach in showing the episodes of a TV series as a single row.
It would be nice if when opening a TV series, the default would be set to the next logical episode and the defaulted selection is the episode itself. Instead, when I open a TV series, it defaults to the first episode and the defaulted selection is the play button at the bottom of the screen, which means when I try to scroll to the right to move to a different episode, it is actually only changing the selected option for the first episode.
And while the selected episode is highlighted, I wish it were possible to make it more obvious which episode is selected. Perhaps as being configurable, but making the thumbnail much larger or something.
Finally, I wish under the Recently Added TV, it would only show the series, and not the specific episodes. If I have multiple episodes which were added, usually the latest episode last, then the latest episode appears first under Recently Added TV. If I were to select it, I would skip over the episodes which had also been recently added. If only the TV series were to appear, it would open the TV series view and per above, default to the next logical episode to play. I know sometimes TV series sometimes appear under Recently Added TVs, but it seems redundant to show both the series and the episode. One advantage of adding the episode in the list is to see which episode was added, but you could also display the same information somehow under the series information.
