Greetings! Most all of my album art displays the lowest resolution for art so that the pictures are blurry. I can go in and manually change all the art to display crisper pictures. However, that process is quite slow. Are there any default settings in plex that I can choose that will automatically assign the highest resolution album art? Thank you
I’m pretty sure Plex does not provide any way for users to alter what it automatically chooses from online databases.
As far as I know, the only control you have over this is to download the album art you want, and configure Plex to use local media. The upside of this is that you have pretty complete control over all your metadata, including artwork. The downside is, if you don’t have your embedded tags in good shape, there could be a lot of work to get there.
Thank you, Beckfield
