Definitive IPv6 Guide?
Server Version#: 1.25.6.5545
Player Version#: 4.69.1
So I have a server which is in a Datacenter - so there’s no NAT, NAT64 etc, it’s got both IPv4 and IPv6 as public IP’s.
No matter what combination I try of custom server URL in Settings → Network, I cannot get the streams to work via IPv6, they’re always via IPv4. Nearly EVERYTHING else is v6, but the websockets aren’t as show in this IPFoo output:
I have added the custom URL as https://xxxx-xxxx…serverid:32400/web as in a number of other threads, but my sockets are always v4. All of my devices are getting Disney+/YouTube via v6, so I know the house is working correct.
All devices are dual stack.
Any help appreciated!
D
That’s definitely wrong. Manual Custom server access URLs shouldn’t include the trailing /web. But I don’t think a manual entry is still required!
I was looking at this the other day, and IPv6 seems to be working automatically now.
Ipv6 support for myplex - #392 by Volts
I haven’t investigated which clients support IPv6. I know that Apple tvOS and iOS do. They prefer IPv4 when available.
So try taking it out, and then do this -
Get your Plex token:
Finding an authentication token / X-Plex-Token | Plex Support
Put it in this URL:
https://plex.tv/api/resources?includeHttps=1&includeIPv6=1&X-Plex-Token=TOKEN
It will show the URLs that Plex is registering with the Plex cloud.
Done - no change unfortunately. The api call shows only IPv4 addressing, in public address and connection protocol data.
Have verified that 32400 is open to IPv6, so kinda at a loss here.
Dumb question, but I assume SettingsNetworkEnable server support for IPv6 is checked?
And the server has a GUA?
Eep! Sorry, I copied the URL wrong before. Try this!
https://plex.tv/api/resources?includeHttps=1&includeIPv6=1&X-Plex-Token=TOKENHERE
Yes - it’s in a datacenter, so it has an 100% static IP. Fully routable, available, I can get to it from my connection and DNS AAAA record has been added. Have done a port scan from an IPv6 host and port is open.
Enable Server Support for IPv6 is ticked.
Datacenter doesn’t imply IPv6!
What’s the prefix? Somewhere in 2000 to 3fff?
Wait - now I’m lost. What’s been added?
Are you trying to use the automagical blah-blah—blah.guid.plex.direct names and certificates, or your own hostnames and certificates?
If you want to use a personalized URL, the format would be https://hostname.blah.com:port - no trailing /web component in the URL.
Yes I understand, but as I’m the network engineer I know it’s ipv6 :wink: It’s dual stacked with a v4 and v6 static - as it’s in a DC there’s no DHCPv6/SLAAC or RDNS, it’s all 100% manual (but definitely v6)
Purely for my own use and testing - it’s just so I can use a hostname, but it doesn’t change anything to do with plex, just the certs I use for the UI, which are LE (but require a hostname).
That’s even worse! lol
We know that Plex is particular about IPv4 address ranges, and I noticed that it doesn’t register IPv6 link-local addresses. That’s why I’m curious if you’re using addresses from the official GUA range.
I’m curious. What happens if you set Settings → Network → Custom server access URLs like this?
http://[colon:separated:ip:v6:ip:addr:like:this]:32400
Note: Include the square brackets.
Is it then published, using @Volts directions above to test? On my own server I can publish valid IPv6 addresses in this manner (though mine works using Plex’s automatic detection as well).
If that works, it’s likely that Plex’s servers are unable to detect your IPv6 address for some reason.
AFAIK the Plex Media Server identifies its own IPv6 GUA and ULA addresses and publishes them.
Or if you manually enter an address (in the format you describe) that’s immediately published.
I don’t see any “detection” of IPv6 from the Plex cloud servers, or any reachability testing from the Plex cloud. It doesn’t use the same mechanisms as Remote Access does for IPv4.
The ULA address mine auto-publishes isn’t reachable remotely. And I can publish random not-mine or not-reachable IPv6 addresses.
Yep, I was unsure about this myself; I may have used “detection” a little loosely there. Since this topic has warmed up again lately I’ve been planning to perform some testing to gain a little more knowledge of how it works.
:slight_smile: Let me know if you see anything different from what I’m seeing! Please look at my comments here too.
Okay results are getting weird, but I’ve gotten one result to work.
If I go to the URL of the server direct: (https://[xxx.xx.xx]:32400, it tries to redirect me to app.plex.tv and is unable to complete the request.
It then redirects to plex.tv - I click Open App and it opens my server through apps.plex.tv and lo and behold - there is an IPv6 entry for plex.direct. I play content and it’s using the ipv6 websocket.
So not working direct, but works through app.plex.tv.
