[DELETE] DTS Audio Problem
Please remove this thread. It wasn’t XPlay. It was the Sonos Playbar which can’t handle DTS
I’ve just started using XPlay on my newly purchased LG TV (UH750V - 2016 model). It seams like there is some kind of problem, when playing DTS files by Direct Play. - Correct me if I’m wrong =)
It works if I disabled Direct Play. I would really like to play it with Direct Play (if possible). Is this a limitation of the TV or XPlay?
Example file:
4ksamples.com/elysium-2013-2160p-1-minute-sample-footage/
Thansk in advance
//CP
Marked as answered …
