over the years (thanks Plex!), I watched and deleted lots of content, through Plex. Although Plex deletes the actual file, it leaves the folder structure.
Is anyone aware of a way of removing empty folders if all the content has been deleted? Will just help me keep things cleaner.
Not within plex.
http://lmgtfy.com/?q=windows+delete+empty+directories+recursive
LolNot within plex.
Would be nice if Plex had an option to delete empty folders as part of its clean up, but good and aware there are alternative ways.
I periodically run the Remove Empty Directories app, to get rid of them
Hello,
I was looking for something like that… how to delete empty folders and other files after removing the video?
So I made a simple program to deal with it… You can use if you want to:
It will scan a path (like C:\user\Videos) for empty folders and remove them for you.
