when i did from the plex web… where does it go on the synology?
when I had my server in windows i’d go to the recycle bin to REMOVE it from the server
does the synology have something that needs to be emptied out?
That’ll depend on how you configured the drive/share on your Syno.
If you have enabled its system trash and the file is within the limit of that trash’s capacity, the file might end up in that system trash.
