Deleting recordings from DVR
Server Version#:
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I recently setup my plex for live TV and DVR recording. I purchased a HDRunner prime. Purchased a lifetime Plex subscription and worked through all the hurdles to get this all setup. I assumed through all this that the process to delete recorded shows would be very very much like that of a Tivo or most DVR offerings from cable companies.
I’ve had little luck finding documentation on how to do this on Plex. The only thing I found seems to indicate that only the Admin can delete recorded shows, and again no details on the steps to do so.
After all this expense, time and effort I’m going to be very disappointed if there isn’t a simple easy “DVR” way each user or the system itself can handle removing watched recordings or just allowing the users to delete one that they don’t plan on watching…
I’d very much appreciate an education on how this is done.
Thanks in advance.
The directions vary slightly depending on what client you are using.
The basic keep x number of episodes and delete after (admin)watching is under the advanced button when you setup the scheduled recording. At the bottom of this doc Setting up Record
Usually a long press on the show will bring up an additional menu.
Is it true that only the admin can delete a recording?
Yes, to protect against accidental deletion.
