Describe Your Plex Setup - Give others an idea of what they can do
I began using Plex years ago during the bleeding edge of the app. Back then, it was hard to find help or someone who did what I was trying to do. To begin, I purchased a WD PR2100 NAS which “was” capable of running the server and housing my shows/music in one nice neat box.
As soon as HDHomeRun came out with their tuners that were compatible with Plex, I purchased one with 3 tuners so we could watch or record directly from cable since my wife was traveling a lot at the time. This would allow her to watch our cable or recorded shows from anywhere via Plex. Of course I have to pay a minimal monthly charge for a card to allow the HDHomeRun to access my cable.
The PR2100 comes with 2 drives. I started out with two 2TB drives and setup RAID so one drive would backup the other. I ran out of storage space after a couple years and swapped each of those drives for 6TB. That was easy enough since they were hot swappable. The RAID recognized the other drive had changed and automatically copied itself to the new drive. Once that was done, I replace the other 2TB drive and once again, all the data was copied. Now I have 6TB of storage space.
Shortly after that, I felt the PR2100 didn’t have the guts to be worked as hard as I was working it so I purchased a Windows 10 Pro with I7 processor which gave me plenty of computing power. Running the Plex server on the PR2100 along with storing data was becoming very problematic and crashes would occur regularly. So I installed the server software on the Win10 machine which really works great! I had the bright idea of allowing the NAS Plex server to run and only use it for music.
What do I need all that computing power for? I record lots of movies and TV shows. Once they have finished recording, they are saved to a 2nd hard drive on the Win10 machine. I then use a program called MCEBuddy which watches this folder and automatically strips the commercials, changes the quality, raises the volume, creates a subtitle file, changes the file format to MP4 and finally moves the saved show/movie to the NAS drive in their various folders such as Plex/TV/Seinfeld or Plex/TV/Big Bang where Plex keeps watch. By the way, Plex does a great job of recording an entire series. If you set up Plex to record all the old & new shows in a series, when it finds an episode that it doesn’t have, it gets recorded. I have the entire series of MASH, NCIS, Big Bang, Seinfeld, etc. Yes, I know Plex can strip commercials but I like the other capabilities of MCEBuddy.
One other thing I’ve done to help Plex in my setup is to hardwire everything. Yep, even the smart TVs have CAT5.
What is your Plex setup like?
Like your System.
Main Plex Box
Dual Xeon (12core X 2) 2.8Ghz
128 GB Ram
SSD 1 TB linux boot Drive, Win 10 Boot Drive
4TB Hard drive in system
Nvidia 1080tI 11Gb
Nvidia 1070 Ti
4 8tb Seagate Drives, Two 10Tb Seagate Drives in Probox 8 bay Drive Case Usb 3.1 c cable
System:
Host: pita-24.lan Kernel: 5.7.16-200.fc32.x86_64 x86_64 bits: 64
compiler: gcc v: 2.34-4.fc32) Desktop: MATE 1.24.1
Distro: Fedora release 32 (Thirty Two)
Machine:
Type: Desktop System: ASUSTeK product: Z10PE-D16 WS v: N/A
serial: <superuser/root required>
Mobo: ASUSTeK model: Z10PE-D16 WS v: Rev 1.xx
serial: <superuser/root required> UEFI [Legacy]: American Megatrends
v: 3407 date: 03/10/2017
Battery:
ID-1: hidpp_battery_0 charge: N/A condition: N/A
model: Logitech G903 Wired/Wireless Gaming Mouse status: Discharging
CPU:
Topology: 2x 12-Core model: Intel bits: 64 type: MT MCP SMP arch: Haswell
rev: 1 L2 cache: 60.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 229889
Speed: 2813 MHz min/max: 1200/3000 MHz Core speeds (MHz): 1: 2813 2: 2517
3: 2277 4: 2280 5: 2456 6: 2744 7: 2664 8: 2654 9: 2801 10: 2551 11: 2417
12: 2548 13: 2400 14: 2782 15: 2482 16: 2479 17: 2659 18: 2513 19: 2346
20: 2685 21: 2515 22: 2544 23: 2108 24: 2478 25: 2519 26: 2558 27: 2210
28: 2529 29: 2491 30: 2568 31: 2732 32: 2802 33: 2170 34: 2780 35: 2555
36: 2657 37: 2692 38: 2722 39: 2622 40: 2556 41: 2755 42: 2576 43: 2747
44: 2493 45: 1976 46: 2564 47: 2285 48: 1693
Graphics:
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Gigabyte
driver: nvidia v: 450.66 bus ID: 03:00.0
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 450.66 bus ID: 82:00.0
Display: x11 server: Fedora Project X.org 1.20.8 driver: nvidia
note: display driver n/a - try sudo/root
unloaded: fbdev,modesetting,nouveau,nvidia,vesa resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Audio:
Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GP102 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 03:00.1
Device-3: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 82:00.1
Device-4: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus ID: 7-1:2
Device-5: Logitech PRO type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 7-2:3
Sound Server: ALSA v: k5.7.16-200.fc32.x86_64
Network:
Device-1: Intel I210 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.6.0-k port: 5000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 14:dd:a9:d4:ed:d4
Device-2: Intel I210 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.6.0-k port: 4000 bus ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: 14:dd:a9:d4:ed:d5
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown
mac: 82:9c:7b:8f:5a:d5
IF-ID-2: virbr0 state: down mac: 52:54:00:95:70:b4
IF-ID-3: virbr0-nic state: down mac: 52:54:00:95:70:b4
IF-ID-4: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-5: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Drives:
Local Storage: total: 46.39 TiB used: 24.80 TiB (53.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM014-1EJ164 size: 931.51 GiB
temp: 39 C
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
temp: 32 C
ID-3: /dev/sdc vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
temp: 37 C
ID-4: /dev/sdd vendor: Seagate model: ST4000DM000-1F2168 size: 3.64 TiB
temp: 36 C
ID-5: /dev/sde type: USB vendor: Seagate model: ST8000DM004-2CX188
ID-6: /dev/sdf type: USB vendor: Seagate model: ST10000DM0004-1ZC101
ID-7: /dev/sdg type: USB vendor: Seagate model: ST8000DM004-2CX188
ID-8: /dev/sdh type: USB vendor: Seagate model: ST8000DM004-2CX188
ID-9: /dev/sdi type: USB vendor: Seagate model: ST10000VX0004-1ZE101
Partition:
ID-1: / size: 797.86 GiB used: 506.27 GiB (63.5%) fs: ext4 dev: /dev/sdc5
ID-2: /boot size: 687.7 MiB used: 336.5 MiB (48.9%) fs: ext4
dev: /dev/sdc2
Swap:
ID-1: swap-1 type: partition size: 119.21 GiB used: 83.5 MiB (0.1%)
dev: /dev/sdc3
Sensors:
System Temperatures: cpu: 94.0 C mobo: 25.2 C gpu: nvidia temp: 59 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 886 fan-4: 0 fan-5: 0
fan-6: 1112 fan-7: 1137 fan-8: 0 fan-9: 0 gpu: nvidia fan: 0%
Voltages: 12v: N/A 5v: N/A 3.3v: 3.26 vbat: 3.31
Info:
Processes: 722 Uptime: 8h 09m Memory: 125.78 GiB used: 15.59 GiB (12.4%)
Init: systemd runlevel: 5 Compilers: gcc: 10.2.1 clang: 10.0.0 Shell: bash
v: 5.0.17 inxi: 3.1.03
[stevef@pita-24 ~]$ sudo inxi -Fx
System:
Machine:
Type: Desktop System: ASUSTeK product: Z10PE-D16 WS v: N/A serial: N/A
Mobo: ASUSTeK model: Z10PE-D16 WS v: Rev 1.xx serial: 150647303100079
UEFI [Legacy]: American Megatrends v: 3407 date: 03/10/2017
Battery:
CPU:
bogomips: 229889
Speed: 2643 MHz min/max: 1200/3000 MHz Core speeds (MHz): 1: 2643 2: 2728
3: 2503 4: 2340 5: 2793 6: 2730 7: 2738 8: 2275 9: 2682 10: 2516 11: 2651
12: 2590 13: 2655 14: 2567 15: 2359 16: 2537 17: 2784 18: 2442 19: 2771
20: 2758 21: 2267 22: 2383 23: 2253 24: 2320 25: 2581 26: 2661 27: 2700
28: 2648 29: 2598 30: 2571 31: 2813 32: 2780 33: 2564 34: 2749 35: 2501
36: 2639 37: 2787 38: 2633 39: 2632 40: 2615 41: 2637 42: 2591 43: 2713
44: 2588 45: 2530 46: 2694 47: 2560 48: 2694
Graphics:
Display: server: Fedora Project X.org 1.20.8 driver: nvidia
note: display driver n/a unloaded: fbdev,modesetting,nouveau,nvidia,vesa
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
direct render: Yes
Audio:
bus ID: 7-2:3
Network:
Drives:
temp: 39 C
temp: 32 C
temp: 37 C
temp: 36 C
size: 9.10 TiB temp: 5 C
Partition:
dev: /dev/sdc2
Swap:
dev: /dev/sdc3
Sensors:
System Temperatures: cpu: 94.5 C mobo: 25.1 C gpu: nvidia temp: 58 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 864 fan-4: 0 fan-5: 0
fan-6: 1100 fan-7: 1137 fan-8: 0 fan-9: 0 gpu: nvidia fan: 0%
Info:
Processes: 721 Uptime: 8h 10m Memory: 125.78 GiB used: 15.58 GiB (12.4%)
Very Silly System / Works well
Silly? NOT! but sounds a bit over the top. Now please don’t tell me you use it as a glorified DVR? It sounds like my Tesla. Yes, I could have bought a Chevy but as my wife put it, “You worked with computers all your life. It just makes sense you drive one.” Oh so much power! Way to go Stevef!
Server is an old Nvidia Shield TV. Files are stored on a Synology NAS, but were on a Windows SMB share for a long time prior to that. The Shield server was very shaky for the first couple of years, needed constant reboots and hugs, but eventually Plex server updates made it very stable.
I have a lifetime Plex Pass, but I honestly rarely use Plex. I got the pass years ago when the lifetime sale offer came by, to enable syncing to my iPad (so I could watch shows on the bus to work without using costly mobile bandwidth). Unfortunately, syncing has never worked for me. And that’s my Plex story.
This is my Daily Driver PC as well. With Proton on Steam for Wibblowz Games, Crossover / Wine
most Win Apps run; Exanple Office 2010.
Thanks for the input Banzai…as to Lifetime Plex Pass…Me Too!
As for the syncing, I use it all the time. I have the entire Seinfeld and Big Bang series on my pad for when I need a laugh and add movies for when I’m traveling since my pad is Wifi only. I’ve had issues with it where I’ve had to delete the download, restart the pad & resync. My wife had all kinds of problems with her old iPad because it didn’t have near enough memory. But we now both use Amazon pads and added 256 GB of external memory.
I have TONS of movies & shows I’ve recorded from live TV and stripped the commercials. The typical TV show is only about 18+ minutes long with more than 10 min of commercials. So I use Plex pretty much daily. We have an LG big screen Smart TV which has the Plex app. This app has issues but works most of the time if I don’t try to force it to do something. But when all else fails, I cast from pad to Chromecast which works great.
I’ve considered a similar setup but was concerned with Wine as being a gimmick? I may have to look into it more seriously.
I think there is something about goofy the sync process with the Shield specifically. If you don’t have an external drive there is not a lot of room for metadata or transcode’s temporary files… and there is no way to tell sync to just copy the original file to your device.
I recently added an external drive for Plex, so sync may work better now… but since I don’t have to leave home nowadays I haven’e tried it. :stuck_out_tongue:
