Desktop player transcoding after being paused
Server Version#: 1.26.0.5715
Player Version#: 1.44.0.2981-e2d72ac2
I have some issues with local transcoding. when I leave the player paused then come back later hours later it will start transcoding. if I want it to stop I have to restart the player. with out restarting plex, playing the same or different tv show doesn’t change anything it will still transcode
the log says Direct Play is disabled but i can play the file fine normally
DEBUG - [Transcode] Found session GUID of mgrxxknpg8pfanwwg3i42d4g in session start.
DEBUG - [Transcode] TranscodeUniversalRequest: using profile Plex Desktop
DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/132253?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=x52yoyngvikqo5wxr8tjjkcs
DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
DEBUG - [Transcode] Selecting best audio stream for part ID 276863 (autoselect: 1 language: en)
DEBUG - [Transcode] Audio Stream: 664024, Subtitle Stream: -1
DEBUG - [Transcode] MDE: Selected protocol http; container: mkv
DEBUG - [Transcode] MDE: analyzing media item 245443
DEBUG - [Transcode] MDE: E2 - An Evil Within: Direct Play is disabled
DEBUG - [Transcode] MDE: E2 - An Evil Within: no direct play video profile exists for http/mkv/hevc
DEBUG - [Transcode] MDE: E2 - An Evil Within: no direct play video profile exists for http/mkv/hevc/aac
DEBUG - [Transcode] Streaming Resource: Calculated bandwidth of 9471kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
DEBUG - [Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
DEBUG - [Transcode] Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41, disable video DS as 8563kbps is > the 1724kbps available, disable audio DS as 457kbps is > the 162kbps available
DEBUG - [Transcode] An Evil Within - video.width limitation applies: 1920 > 720
DEBUG - [Transcode] An Evil Within - audio.channels limitation applies: 6 > 2
DEBUG - [Transcode] MDE: E2 - An Evil Within: Direct Streaming is disabled, so video stream will be transcoded
DEBUG - [Transcode] MDE: E2 - An Evil Within: no remuxable profile found, so video stream will be transcoded
DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
DEBUG - [Transcode] MDE: E2 - An Evil Within: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
