Did SSL fix break TWIT Live Stream
First off, thanks for the SSL fix. It works brilliantly. However, when i try playing the Live Stream from the TWiT channel, i get "Trailer is unavailable". I know this worked prior to the SSL fix. Could it be that the HTTPS is breaking live streams?
In the PlexConnect log i see the following each time i try
12:54:12 ATVLogger: loadURL (override): http://atv.plexconnect/video/twittv/:/function/LiveStream?function_args=Y2VyZWFsMQoxCmRpY3QKMgpzNwpVc3RyZWFtczEyCmhsc19wcm92aWRlcmIxczE3CmluY2x1ZGVfY29udGFpbmVycjAK&PlexConnect=ChannelPrePlay
12:54:12 WebServer: serving .xml: /video/twittv/:/function/LiveStream?function_args=Y2VyZWFsMQoxCmRpY3QKMgpzNwpVc3RyZWFtczEyCmhsc19wcm92aWRlcmIxczE3CmluY2x1ZGVfY29udGFpbmVycjAK
12:54:13 WebServer: serving  /Users/rob/Development/PlexConnect/assets/js/utils.js
I can confirm this issue. TWIT live worked before the https fix but it does not now. It still works fine on Plex iOS.
What is this SSL fix discussed above?
The issue I am having is the Twit.tv plugin for video no longer brings up any twit.tv shows.
Apple's change from http trailer.apple.com requests to secured ones: https, ssl.
Its all working for me. The TWIT Live started working a few days ago and the archived shows I tested all work.
