Difference between 1.22.0.4157 and 1.22.0.4163
What is the difference between Plex Media Server 1.22.0.4157 and 1.22.0.4163 ?
Didn’t use to be a version change between beta and release
To solve a PMS shutdown hang issue on Linux
This is what is listed on Plex Media Server Release Notes
Version 1.22.0.4163New
  • New Beta Plex TV Series agent
  • (Library) Allow TMDB id matching in Fix Match using 'tmdb-` prefix (#12389)
  • (Library) Show unmatched filter for episodes.
Fixes
  • (Library) Manually unmatched items in Plex Movie libraries would get rematched when refreshing (#12281)
  • (Library) Rematching would occur for all unmatched episode items after every scan on the Plex TV agent.
  • (Library) Scanning in a TV folder containing optimized versions could match episodes to the the wrong show (#12381)
  • (Library) Shows and Artists wouldn’t show play history for their items if the agent had changed (#12354)
  • (Library) The server could crash when loading certain home screen items.
  • (Linux) The server would take long to shutdown when asked to terminate (#12459)
  • (Metadata) Embedded studio tags were not being read correctly for Plex Movie items (#12242)
  • (Network) Bandwidth controls would sometimes limit bandwidth too much (#12399)
  • (Playqueue) Newly created play queue would not place specials from TV Shows in the correct order (#11994)
  • (Scanner) The Plex Movie scanner may not pick up extras and subtitles for media with unicode characters in the filename.
  • (TV) The beta TV agent could overwrite EPG metadata for a show.
  • (Transcoder) Sessions could become unresponsive after seek requests with certain timings, most commonly seen on Samsung devices (#11703)
This is listed on Announcements Plex Media Server 1.22.0.4163 is now available to everyone.
and then your reply.
How about just listing the changes so we can make a judgement to install the version or not.
Thats for Plex to do. I have no control over that. Just telling you what I know and the difference.
It is listed but are you wanting just a list of the delta between beta and public? What if others are not using beta nor tracking the changes on beta? How would they see all the changes since the last released public version, if all changes are not listed for the current?
Good point.
Thanks for info)
