Difference between "official" branch and main version?
I really need to say thanks again for developing this - so, so happy.
I noticed the post on the Plex blog about PC and was wondering what the difference was between the Plex build and the original version? If I install the Plex branch will it still receive updates from the trunk?
The plexinc build is quite far behind in terms of nuts and bolts development. The plan, as I understand it, is to roll the interface elements of the plexinc-élan build into the base shortly, after the foundation is set.
institute11: correct.
nblee: "receive updates"? There is nothing like "receiving" updates... currently you have to pull them yourself, from whichever source you want.
