I have the problem that when I add music different albums arise? This while the album tag has the same name.
How can I solve this?
Server Version#: 1.19.1.2701
Player Version#: 1.12.0.1232-aacabe78
Both the folder organization and the embedded meta tags need to agree on the following:
So, for proper function of Plex, you need to organize your music into a folder structure like this:
Music / AlbumArtist / AlbumTitle / Tracks
(āAlbumTitleā can also be a Single or EP release.)
If you enable āPrefer local metadataā, all your tracks must have complete and correct embedded meta tags.
The meta tag āAlbumTitleā must have identical content for all tracks of an album.
The āDisc Numberā does not belong into the Album Title tag, but into a separate āDisc Numberā tag!
All tracks must also have identical content in the āAlbum Artistā meta tag. For sampler albums, this is usually āVarious Artistsā.
Each track must also have the āTrack Numberā metatag populated.
Here is an example how this works:
āAlbum Artistā must have identical content for all tracks of one album.
In this case this can be āVarious Artistsā or whatever you choose.
A playlist is not an album, though.
Do the tracks have each a āTrack Numberā meta tag?
Are they all stored within the same folder?
The numbers donāt have a Track Number. After I correct all numbers with a Track Number it works. Thank you for your help
