I was wondering would it be easier on my older computer that houses my plex files to direct play instead of transcoding? Also before I had tried to share some video through plex with a family member. It seemed to really slow my internet speed. Would direct play have any bearing to change that? I am using only the 4k firestick on all TVs
Yes!
Direct play is always easier on your computer than transcoding!
Direct play is always the goal but internet speed is a barrier that may be an insurmountable obstacle
You can try to keep lower bandwidth copies or optimize some of your media for streaming to help
if you have a very slow upload speed and they have a low download speed, there might be nothing you can do.
You should also double check to make sure your remote access is working properly. If it’s not, you can get what’s called a relay connection which slows down everything to 2 Mbps
You can view this in the server settings dashboard when something is playing
In each client (on the Firestick) there are also bandwidth limits that should be changed. The default is usually too low at 2 to 4 Mbps 720p
This can cause a lot of unnecessary transcoding
is there a way I can tell if something is direct playing?
Server settings → Dashboard → Show details
It will say local, indirect, or remote where the yellow box is
Direct Play or Transcode where the arrow is
