@stevesolo
This is basic setup with the AVI.
- The TV (main) output of your AVR plugs into the TV as always
If your TV has a HDMI port which also provides EARC return, plug the AVR into that port.
- The player device(s) plug into any one of your AVR’s HDMI input ports
- On the AVR, select the desired input
@ChuckPa
So I think that’s what I have now. The Chromecast is plugged into the AVR and when the corresponding input is selected the Chromecast dashboard is shown on the TV. Correct me if I am wrong, but with this configuration, direct play won’t work as we determined, only if I bypass the receiver. Essentially, it would be great if I can have the Chromecast HDMI video going to the TV while the HDMI or optical audio goes to the receiver.
Update: apparently the new Chromecast with Google TV (which I have) allows for the audio to be sent over bluetooth. So perhaps I can plug the Chromecast into the TV for video and then get a wireless bluetooth adapter for the receiver, like this one and use that for audio.
Spoke an A/V company our family has used before and the original suppliers of the current old Integra DTR 20.3 (they said it’s ~10 years old, lol. It was given to us from my father-in-law a few years ago.) They recommend the Denon AVR-X1700H.
There you go. The 10 year age explains why it can’t support what you need.
That is a good Denon. It will serve you VERY well.
It’s about the same price as I paid for my Onkyo a few years ago.
