My computer (i7 3.5) will not stream 4k (hard wired) without stuttering.
This is because of transcoding??
Will it help if I just stream directly?
Did I need to manually convert the file somehow?
I’ve tried putting it on the plex cloud.
4k version won’t even load up without getting a “took too long to load” error.
I have a gigabit connection.
Thanks for any help.
jjrjr1
December 28, 2017, 7:43pm
2
In order to direct play 4K it should be encoded like so.
Container = mp4
Video Codec = h265
Audio Codec = AC3 for both 2 or multi channel.
Also to ensure direct play of other formats… substitute h264 for h265.
Like that you media should direct play if you keep bit rates below 12mbps, Ethernet connected (No wifi).
Can you give me directions on how to encode like this?
ChuckPa
December 28, 2017, 8:32pm
4
Before you go too deep there,
Can you grab the log files? It’s a good idea to see what PMS thinks of the file(s). It might be a simple issue of your network is too slow.
Sure… where and which log file?
ChuckPa
December 28, 2017, 8:59pm
6
settings - server - help - download logs.
Please attach the ZIP file it gives you.
Here ya go…
Tell me if you need me to try to play the 4k video right before I download logs.
ChuckPa
December 29, 2017, 5:07pm
8
PMS thinks it has to transcode and the server isn’t strong enough to transcode it at real-time speed.
speed=x.x tells us the realtime factor. 2.0 means it’s transcoding 2x faster than real-time need.
You’re getting less than 1.0. This is verification it’s the CPU/video and nothing else.
For the movie: Apollo 13, it sees it as 4K (3840) but your TV/player is only 2K (1920)
It also shows subtitles are embedded in the file and need to be burned in (transcoded) because the player can’t handle that format. (usually only SRT, SSA, ASS can be direct played. Anything else requires the transcoder to merge them into the main video image.
I would next like you to hover over the movie you played with your mouse. Click the ellipsis (...) then click “Get info”.
When this displays, you’ll see “View XML”. Please click that.
A new tab will open showing the tech info of the video.
Please copy/paste it here (using “Code” paragraph formatting in the Paragraph formatter ^^^) or screenshot it.
I suspect it’s HEVC (H.265) and trying to work with it but that Xeon can’t get it done. This is where seeing the XML is what’s needed next.
Nice information. Thanks!
I’m confused as to why it shows my tv as 1920. The tv I’m using the plex app with is certainly 2160.
ChuckPa
December 29, 2017, 7:00pm
10
check the app settings. the app is reporting 1920x 1080p.
jjrjr1
December 29, 2017, 7:46pm
11
LOL
Isn’t that what I said???
Transcode HVEC as
Container = mp4
Video = h265
Audio = AC3
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Movies" librarySectionUUID="2db6a3c2-8a9f-499a-a2f5-b57efa79d2c0" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1513159326">
<Video ratingKey="308" key="/library/metadata/308" guid="com.plexapp.agents.imdb://tt0112384?lang=en" librarySectionID="1" librarySectionKey="/library/sections/1" librarySectionTitle="Movies" studio="Imagine Entertainment" type="movie" title="Apollo 13" contentRating="PG" summary="The true story of technical troubles that scuttle the Apollo 13 lunar mission in 1971, risking the lives of astronaut Jim Lovell and his crew, with the failed journey turning into a thrilling saga of heroism. Drifting more than 200,000 miles from Earth, the astronauts work furiously with the ground crew to avert tragedy." rating="9.5" audienceRating="8.7" viewOffset="605188" lastViewedAt="1514408819" year="1995" tagline="Houston, we have a problem." thumb="/library/metadata/308/thumb/1514531566" art="/library/metadata/308/art/1514531566" duration="8420954" originallyAvailableAt="1995-06-30" addedAt="1513874592" updatedAt="1514531566" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="agent" primaryExtraKey="/library/metadata/309" ratingImage="rottentomatoes://image.rating.certified">
<Media videoResolution="4k" id="1048" duration="8420954" bitrate="44791" width="3840" height="2160" aspectRatio="1.78" audioChannels="8" audioCodec="dca-ma" videoCodec="hevc" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="main 10" title="Original">
<Part accessible="1" exists="1" id="1048" key="/library/parts/1048/1513876942/file.mkv" duration="8420954" file="F:\qtorrent\Apollo.13.1995.2160p.UHD.BluRay.REMUX.HDR.HEVC.DTS-X-EPSiLON.mkv" size="47148314866" audioProfile="ma" container="mkv" videoProfile="main 10">
<Stream id="2163" streamType="1" default="1" codec="hevc" index="0" bitrate="42871" language="English" languageCode="eng" bitDepth="10" chromaSubsampling="4:2:0" colorRange="tv" colorSpace="bt2020nc" frameRate="23.976" height="2160" level="153" profile="main 10" refFrames="1" title="MPEG-H HEVC Video / 36788 kbps / 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020" width="3840"/>
<Stream id="2164" streamType="2" selected="1" default="1" codec="dca" index="1" channels="8" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="7.1" bitDepth="24" profile="ma" samplingRate="48000" title="DTS:X/DTS-HD Master Audio / 7.1-X / 48 kHz / 7230 kbps / 24-bit"/>
<Stream id="2165" streamType="2" codec="ac3" index="2" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" samplingRate="48000" title="Commentary by director Ron Howard"/>
<Stream id="2166" streamType="2" codec="ac3" index="3" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" samplingRate="48000" title="Commentary by Jim and Marilyn Lovell"/>
<Stream id="2167" streamType="3" codec="pgs" index="4" bitrate="52" language="English" languageCode="eng" title="SDH"/>
<Stream id="2168" streamType="3" codec="pgs" index="5" bitrate="48" language="Deutsch" languageCode="ger"/>
<Stream id="2169" streamType="3" codec="pgs" index="6" bitrate="44" language="Türkçe" languageCode="tur"/>
<Stream id="2170" streamType="3" codec="pgs" index="7" bitrate="61" language="English" languageCode="eng" title="Commentary by director Ron Howard"/>
<Stream id="2171" streamType="3" codec="pgs" index="8" bitrate="62" language="Deutsch" languageCode="ger" title="Commentary by director Ron Howard"/>
<Stream id="2172" streamType="3" codec="pgs" index="9" bitrate="66" language="English" languageCode="eng" title="Commentary by Jim and Marilyn Lovell"/>
<Stream id="2173" streamType="3" codec="pgs" index="10" bitrate="66" language="Deutsch" languageCode="ger" title="Commentary by Jim and Marilyn Lovell"/>
</Part>
</Media>
<Media videoResolution="1080" id="1176" duration="8420963" bitrate="9465" width="1920" height="1080" aspectRatio="1.78" audioChannels="6" audioCodec="aac" videoCodec="h264" container="mp4" videoFrameRate="24p" optimizedForStreaming="1" proxyType="42" audioProfile="lc" has64bitOffsets="1" target="Custom: Universal TV" videoProfile="main" title="Custom: Universal TV">
<Part accessible="1" exists="1" id="1177" key="/library/parts/1177/1514525181/file.mp4" duration="8420963" file="F:\qtorrent\Plex Versions\Custom_ Universal TV 48\Apollo 13 (1995).mp4" size="9962628465" audioProfile="lc" container="mp4" has64bitOffsets="1" optimizedForStreaming="1" videoProfile="main">
<Stream id="2439" streamType="1" default="1" codec="h264" index="0" bitrate="8294" language="English" languageCode="eng" bitDepth="8" chromaSubsampling="4:2:0" frameRate="23.976" hasScalingMatrix="0" height="1080" level="40" profile="main" refFrames="4" streamIdentifier="1" width="1920"/>
<Stream id="2440" streamType="2" selected="1" default="1" codec="aac" index="1" channels="6" bitrate="787" language="English" languageCode="eng" profile="lc" samplingRate="48000" streamIdentifier="2"/>
<Stream id="2441" streamType="2" codec="ac3" index="2" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" samplingRate="48000" streamIdentifier="3"/>
<Stream id="2442" streamType="2" codec="ac3" index="3" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" samplingRate="48000" streamIdentifier="4"/>
</Part>
</Media>
<Genre id="60" filter="genre=60" tag="History"/>
<Genre id="61" filter="genre=61" tag="Drama"/>
<Genre id="271" filter="genre=271" tag="Adventure"/>
<Director id="1922" filter="director=1922" tag="Ron Howard"/>
<Writer id="1923" filter="writer=1923" tag="William Broyles Jr."/>
<Writer id="1924" filter="writer=1924" tag="Al Reinert"/>
<Producer id="1631" filter="producer=1631" tag="Brian Grazer"/>
<Country id="70" filter="country=70" tag="US"/>
<Role id="1925" filter="actor=1925" tag="Tom Hanks" role="Jim Lovell" thumb="http://image.tmdb.org/t/p/original/pQFoyx7rp09CJTAb932F2g8Nlho.jpg"/>
<Role id="1926" filter="actor=1926" tag="Bill Paxton" role="Fred Haise" thumb="http://image.tmdb.org/t/p/original/53Ln1wTC0OCLzBF4HNlwhMXYgOU.jpg"/>
<Role id="1927" filter="actor=1927" tag="Kevin Bacon" role="Jack Swigert" thumb="http://image.tmdb.org/t/p/original/rjX2Oz3tCZMfSwOoIAyEhdtXnTE.jpg"/>
<Role id="1928" filter="actor=1928" tag="Gary Sinise" role="Ken Mattingly" thumb="http://image.tmdb.org/t/p/original/n5AbjoNfONICaggp2f1QhYAjAoZ.jpg"/>
<Role id="1929" filter="actor=1929" tag="Ed Harris" role="Gene Kranz" thumb="http://image.tmdb.org/t/p/original/atzm7ZGRFSWJHQT6qKmzjmNQ9GA.jpg"/>
<Role id="1930" filter="actor=1930" tag="Kathleen Quinlan" role="Marilyn Lovell" thumb="http://image.tmdb.org/t/p/original/qxEXUFX8LP7jAgLvB51S1lWB2zn.jpg"/>
<Role id="1931" filter="actor=1931" tag="Mary Kate Schellhardt" role="Barbara Lovell" thumb="http://image.tmdb.org/t/p/original/nN54NVsxm5M6yhdQlSECm2y5vxK.jpg"/>
<Role id="1932" filter="actor=1932" tag="Emily Ann Lloyd" role="Susan Lovell" thumb="http://image.tmdb.org/t/p/original/sVCzK014On8aaQNZsRl6vDgbaII.jpg"/>
<Role id="1933" filter="actor=1933" tag="Miko Hughes" role="Jeffrey Lovell" thumb="http://image.tmdb.org/t/p/original/hpteoojNUAomlQVbiL4eSjUeJ4K.jpg"/>
<Role id="1934" filter="actor=1934" tag="Max Elliott Slade" role="Jay Lovell" thumb="http://image.tmdb.org/t/p/original/g06RM2IWsiw6rvKA6SNsceFsHu5.jpg"/>
<Role id="1935" filter="actor=1935" tag="Jean Speegle Howard" role="Blanch Lovell" thumb="http://image.tmdb.org/t/p/original/6GxAKydN0p77XI0ixTAJeWFPiRR.jpg"/>
<Role id="1936" filter="actor=1936" tag="Tracy Reiner" role="Mary Haise" thumb="http://image.tmdb.org/t/p/original/fsmETZI9aoKZD1CvYlcaTsstuZ9.jpg"/>
<Role id="973" filter="actor=973" tag="David Andrews" role="Pete Conrad" thumb="http://image.tmdb.org/t/p/original/pxmxn29UHW9r6uvLrd7bEwLswlQ.jpg"/>
<Role id="1937" filter="actor=1937" tag="Michele Little" role="Jane Conrad"/>
<Role id="1938" filter="actor=1938" tag="Chris Ellis" role="Deke Slayton" thumb="http://image.tmdb.org/t/p/original/vbltM7DQXON9xvpiyNuUCglNRmz.jpg"/>
<Role id="1939" filter="actor=1939" tag="Joe Spano" role="NASA Director" thumb="http://image.tmdb.org/t/p/original/ApY9rdhS1Qrvd0byprtlMxMAQ1q.jpg"/>
<Role id="1940" filter="actor=1940" tag="Xander Berkeley" role="Henry Hurt" thumb="http://image.tmdb.org/t/p/original/vlZ9FDMk2Xd1WHixPKxnheZoXgR.jpg"/>
<Role id="1941" filter="actor=1941" tag="Roger Corman" role="Congressman" thumb="http://image.tmdb.org/t/p/original/gCfEvxl7jTv2dBo8HvwWVMi3auz.jpg"/>
<Role id="1942" filter="actor=1942" tag="Andrew Lipschultz" role="Launch Director"/>
<Role id="1943" filter="actor=1943" tag="Mark Wheeler" role="Neil Armstrong" thumb="http://image.tmdb.org/t/p/original/5Sx48iaEVE5G4OktUcZ1sJHePeE.jpg"/>
<Role id="1944" filter="actor=1944" tag="Endre Hules" role="Guenter Wendt" thumb="http://image.tmdb.org/t/p/original/cmxqIcfikG6rr5ag45ZkhYMP51Z.jpg"/>
<Role id="1945" filter="actor=1945" tag="Clint Howard" role="Sy Liebergot - EECOM White" thumb="http://image.tmdb.org/t/p/original/d9QW5feIgNwDRdkKK1j7gmmOQXT.jpg"/>
<Role id="1946" filter="actor=1946" tag="Christian Clemenson" role="Dr. Chuck" thumb="http://image.tmdb.org/t/p/original/v1WvZ0EM0pMB0NCaTZ1Yq0nYpsb.jpg"/>
<Role id="1947" filter="actor=1947" tag="Brett Cullen" role="CAPCOM 1" thumb="http://image.tmdb.org/t/p/original/dSucCeOCUJy8nDjUjxmWguu3W1D.jpg"/>
<Role id="1948" filter="actor=1948" tag="Thom Barry" role="Orderly" thumb="http://image.tmdb.org/t/p/original/AhUa78UoZ5oGk5kWiatnDaPxSnO.jpg"/>
<Role id="1949" filter="actor=1949" tag="Gabriel Jarret" role="GNC White" thumb="http://image.tmdb.org/t/p/original/19LMwcgNFfQnmcIkWeb4SVjKNyR.jpg"/>
<Role id="1950" filter="actor=1950" tag="Jim Lovell" role="" thumb="http://image.tmdb.org/t/p/original/t4hYI7BFm4kPbQ0NTDEglelxMjR.jpg"/>
<Similar id="1204" filter="similar=1204" tag="Air Force One"/>
<Similar id="1982" filter="similar=1982" tag="The Fugitive"/>
<Similar id="1983" filter="similar=1983" tag="The Hunt for Red October"/>
<Similar id="1984" filter="similar=1984" tag="A Few Good Men"/>
<Similar id="1196" filter="similar=1196" tag="Twister"/>
<Similar id="1985" filter="similar=1985" tag="Speed"/>
<Similar id="1986" filter="similar=1986" tag="Contact"/>
<Similar id="1987" filter="similar=1987" tag="Big"/>
<Similar id="1203" filter="similar=1203" tag="True Lies"/>
<Similar id="1988" filter="similar=1988" tag="Deep Impact"/>
<Similar id="1989" filter="similar=1989" tag="Con Air"/>
<Similar id="1990" filter="similar=1990" tag="Lethal Weapon 2"/>
<Similar id="1991" filter="similar=1991" tag="Crimson Tide"/>
<Similar id="1992" filter="similar=1992" tag="Lethal Weapon 4"/>
<Similar id="1993" filter="similar=1993" tag="Dances with Wolves"/>
<Similar id="1036" filter="similar=1036" tag="Lethal Weapon"/>
<Similar id="1210" filter="similar=1210" tag="Cliffhanger"/>
<Similar id="1994" filter="similar=1994" tag="Patriot Games"/>
<Similar id="1995" filter="similar=1995" tag="Outbreak"/>
<Similar id="1193" filter="similar=1193" tag="The Perfect Storm"/>
<Extras size="1">
<Video ratingKey="309" key="/library/metadata/309" guid="iva://api.internetvideoarchive.com/2.0/DataService/VideoAssets(5711)?lang=en&bitrates=80,212,450,600,750,1500,8000&duration=97&adaptive=1&dts=0" type="clip" title="Apollo 13" summary="" index="1" year="1999" thumb="/library/metadata/309/thumb/1513874605" subtype="trailer" duration="97000" originallyAvailableAt="1999-09-27" addedAt="1513874605" extraType="1">
<Media videoResolution="720" id="1049" duration="97000" bitrate="1500" width="1280" height="720" aspectRatio="1.78" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="1049" duration="97000" container="mp4" key="/services/iva/assets/5711/video.mp4?bitrate=1500" optimizedForStreaming="1">
<Stream id="2157" streamType="1" codec="h264" index="0" bitrate="1500" height="720" width="1280"/>
<Stream id="2158" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng"/>
</Part>
</Media>
<Media videoResolution="480" id="1050" duration="97000" bitrate="750" width="640" height="480" aspectRatio="1.33" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="1050" duration="97000" container="mp4" key="/services/iva/assets/5711/video.mp4?bitrate=750" optimizedForStreaming="1">
<Stream id="2159" streamType="1" codec="h264" index="0" bitrate="750" height="480" width="640"/>
<Stream id="2160" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng"/>
</Part>
</Media>
<Media videoResolution="480" id="1051" duration="97000" bitrate="450" width="640" height="480" aspectRatio="1.33" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="1051" duration="97000" container="mp4" key="/services/iva/assets/5711/video.mp4?bitrate=450" optimizedForStreaming="1">
<Stream id="2161" streamType="1" codec="h264" index="0" bitrate="450" height="480" width="640"/>
<Stream id="2162" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng"/>
</Part>
</Media>
</Video>
</Extras>
</Video>
</MediaContainer>
jjrjr1
December 29, 2017, 7:57pm
13
LOL
HVEC at almost 48mbps will ALWAYS transcode no matter what you do.
What device are you streaming to at that speed and, of course, remote stream at that BW will be problematic at least.
I suggest you keep your bitrate around 12-15 mbps for your 4K media…
@jjrjr1 said:
LOL
Transcode HVEC as
Container = mp4
Video = h265
Audio = AC3
Maybe ??
Still… I dont know where to change these options, or, what to even use.
This is in Plex settings? Or a separate program I need to use?
@jjrjr1 said:
LOL
I dont know what HVEC is… or how it’s at 48mbps.
I am streaming from my computer to my Vizio TV (not remote… hard wired)
jjrjr1
December 29, 2017, 8:12pm
16
HEVC is High Efficiency Video Codec aka. h.265
The xml you posted shows its at 48mbps.
The xml also says this is in an mkv container with 8 channel dc-ma encoding…
You fix all those things… it will probably Direct Play to your 4K devices.
BTW: be sure your client quality setting is set to “Original Quality”. On some Plex clients I think even that setting tops at 20mbps…
Can you please explain How to fix these problems specifically?
jjrjr1
December 29, 2017, 8:54pm
18
Sure
The files need to be re-encoded in the formats I suggested.
There are Many tools available to do this.
Most folks here use Handbrake.
Search around and you will find lots of tools that can do this for you.
ChuckPa
December 29, 2017, 9:06pm
19
Container = mp4
Video Codec = h265
@jjrjr1
Thanks for your help but I’ve got this. You were the advocate of H.265 which is indeed the issue, with subtitles, to be resolved.
ChuckPa
December 29, 2017, 9:08pm
20
@preynolds2
What are you playing on? (What’s the player?) This will be one facet of the decision.
The other facet are all the PGS (bitmapped) subtitles in the file. If you don’t need subtitles, they can be removed without using handbrake and reducing the quality.
