Hey all.
The PS3 wont directplay even tho the media file meets all the directplay requeriments.
Medie
Video Resolution 1080p
Varighed 1:51:10
Bitrate 1693 kbps
Width 1920
Height 808
Aspect Ratio 2.35
Container MP4
Video Frame Rate 24p
Web Optimized Ja
Has 64bit Offsets 0
Del
Varighed 1:51:10
File deleted file name.mp4
Size 1.31 GB
Container MP4
Has 64bit Offsets 0
Web Optimized Ja
Video
Codec H264
Bitrate 1500 kbps
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Varighed 1:51:10
Frame Rate 24.000 fps
Frame Rate Mode cfr
Has Scaling Matrix 0
Height 808
Level 4.1
Profile main
Ref Frames 4
Scan Type progressive
Stream Identifier 1
Width 1920
Sound
Codec AAC
Kanaler Stereo
Bitrate 192 kbps
Audio Channel Layout stereo
Bitrate Mode VBR
Varighed 1:51:10
Profile lc
Sampling Rate 48000 Hz
Stream Identifier 2
What is wrong?
Guess its becuase of the resolution on that one.
But playing this:
Medie
Video Resolution 720p
Varighed 1:53:52
Bitrate 4147 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Container MP4
Web Optimized Ja
Has 64bit Offsets 0
Del
Varighed 1:53:52
File Are You Here (2014).mp4
Size 3.30 GB
Container MP4
Has 64bit Offsets 0
Web Optimized Ja
Video
Codec H264
Bitrate 4000 kbps
Bit Depth 8
CABAC 0
Color Space yuv
Varighed 1:53:51
Frame Rate 23.976 fps
Frame Rate Mode cfr
Height 720
Level 4.1
Profile baseline
Ref Frames 1
Stream Identifier 1
Width 1280
Sound
Codec AAC
Kanaler Stereo
Bitrate 247 kbps
Bitrate Mode VBR
Varighed 1:53:52
Profile lc
Stream Identifier 2
Gives me same issue? Nothing is Directplayed?
Requrirments:
- Container: MP4
- Video Encoding: H.264
- Audio Encoding: AAC
- Bitrate: 20Mbps or lower
It's not direct playing because of "Level 4.1"
We can only Direct Play Level 4.0 safely.
Technically we could probably direct play this video also. But before we do we need to know the peak bitrate for the video. The peak bitrate for Level 4.0 is 20Mbps. The peak bitrate for Level 4.1 is 2+ times higher. We're figuring it out.
Thanks for quick reponse.
So i dont need to redo all my media files?
But expect a fix?
Damn! First time I heard of the level 4.0 qualification.
No wonder my BluRay and DVD rips transcode even though the bitrates are certainly lower than the 20Mbs mentioned in the FAQ and probably have an average in the 2-4Mbs range. I even switched to MP4 containers from my usual, favourite MKV to get Direct Play with little or no luck. I'm pretty sure I've read every post for direct play problems, and where people have include the media info the Level 4.0 qualifier was never mentioned when that was more than likely the real problem.
No biggie, my server can transcode or re-mux, but maybe update the FAQ for the media types for PlayStation to include that important piece of information (and reference frames too, if that is part of the problem) In the meantime, I'll keep this in mind for future rips.
Absolutely. We got the TV FAQ updated but I think we missed the PS3/4 FAQ.
The L40 restriction is something we're trying to work around. So many files are encoded at L41 but actually are entirely within the bitrate range of L40 - meaning we have no reason _not_ to play them. Definitely talking / testing around L40 vs L41 playback.
Direct Play or Bust.
4.1 being Directplayed on all the other devices.
Except Playstation, would be a bummer if that is the only one not accepting 4.1 for directplay
And i guess 80% of Plex users got their Lib in 4.1 since its almost standard in encode programs.
