Disable 'Manage Recommendations' when Visibility is 'Exclude...'
On the Manage Libraries page, the “Home” column checkboxes under “Manage Recommendations” should be disabled when the Library’s “Visibility” setting is set to “Exclude from home screen.” A line of text, or a tooltip, explaining why the settings are disabled would be helpful, too.
As it is, a user might make several selections in the Home column, forgetting that the library is excluded, and be frustrated when they find their changes are not reflected on the Home page.
