Disable Skip Credits
Please, can you help me to disable that feature? The button bothers me. I cannot see the screen properly.
Thanks. Regards,
Depending on what player app you’re using, there should be an option in Settings > Player Experience to disable this:
Skip Credits → Disabled
belated thank you very much!!!
