How do I stop Tidal defaulting to 1st selection each time I select ‘music’ on my app?
Even though ive disabled it in online media sources within the app it still shows, I hate it!
Which app are you using?
Which version number(s)?
Its latest android app from Play, seems it defaults to Tidal on first run of app then if you change folder, it reverts to that after on each run so can kinda live with that! thanks.
I can understand Tidal meesage in the free version. As a Plex Pass user I should be able to disable all Tidal references & defaults.
https://app.plex.tv/desktop#!/settings/online-media-sources
set it to ‘Disabled’
I did find that in Plex Webpage/Account/Online Media Sources.
Thx for your response.
this helped!!! SOLVED
