Discard changes to Settings.py
Hi
I believe I made the mistake of changing Settings.py somewhere along the way. When I try to update PlexConnect via Git I get a message saying:
"Your local changes to the following files would be overwritten by merge:
    Settings.py
Please, commit your changes or stash them before you can merge."
Can I easily use Git to undo all changes I have made to Settings.py or replace the old file with a new one? Or is there any other way to get around this issue?
Well just keep your .cfg and just remove the rest except for certs and download them again, should do the trick I think
