Update PlexConnect issue :(
Hi PlexCommunity,
I have a problem when i try to update my PlexConnect Folder?
Last login: Wed Feb  5 16:10:56 on ttys001
ives-macmini:Plexify iveflammang$ git pull
Updating e5d9ea6..3df7252
error: Your local changes to the following files would be overwritten by merge:
Settings.py
assets/js/application.js
assets/js/utils.js
assets/templates/Show_Grid.xml
assets/templates/Show_List.xml
support/OSX/createcert.bash
Please, commit your changes or stash them before you can merge.
Aborting
What am i doing wrong?
Thx for any help:)
Well, you changed a couple of source files...
github is warning you, that you would loose your work if it just overwrites them. I guess you somehow have to discard (stash?) those changes, before re-trying.
Yes, I changed the Webserver.py to get the Plex Icon on iMovie Theater.
so now i can't update anymore?
How do i have to discard this settings, to get my folder updated with the last Plexconnect version?
Or do i have to stay with?
thx Plex Star
You no longer have to edit Webserver.py to use iMovie Theatre. You just edit the hosttointercept in Settings.cfg.
I meant that i changes the webserver.py to get a Plex Icon instead of trailers or imovie icon?
Sry for my bad english ;(
undo the changes as you only need them for the install.
it does look like you changed more than that though
Nah, my fault, I just misread.
