i have downloaded from github a coupple of days ago.
now when it has come some bug fixes how do i update? delete and download all again?
or is there any command in terminal that i can use?
EDIT: Be aware though that the settings file has just been reworked so you may want to check you get the new one and set it up again.
thanks =)
Does git pull in a new terminal window do the same thing? That's what I've been doing...
Yes - be aware though that the settings file has just been reworked so you may want to check you get the new one and set it up again.
