Discover not finding Peacock / Peacock Premium
When I try content that’s available on Peacock (using the iOS client) it cannot find the Peacock app (or Peacock Premium, even though it’s the same app). App version is 8.3 .
What is Peacock?
[edit] I see, it’s an online video streaming service. You are trying to use deep-linking from Plex to the Peacock app.
I assume this is on Android. Android TV or Andoid mobile?
It’s on iOS. iPhone.
Which content specifically were you trying to open? I just tried the movie Firestarter 2022 and it opened the Peacock app
Below Deck Down Under. Here’s some screenshots.
I’ll note when I try Firestarter 2022 it doesn’t work for me either. Same error message (just different art on the screen).
ok. That Below Decks Down Under show works for me as well. Is it possible to get your iOS logs so I can ask one of the devs to check. (you can message them to me)
Are by any chance running a network wide ad blocker like pihole which might be blocking click.justwatch.com
Do links to other apps you might have work? wondering if maybe parental controls might be causing it if not an ad blocker
I am running a PiHole…good call. But I dropped to cellular and restarted, and now instead of an error it just sends me to the App Store to the Peacock page.
The Rookie via Hulu loads fine. So does Chip N Dale Rescue Rangers from Disney Plus. Seems to only be a Peacock thing. I’ll make some logs and DM them to you. Thanks!!!
It appears Peacock made some changes to the format the app accepts for deeplinks. We made a change on our end. Can you please try again.
That did it. Works now on iOS! Thanks!!!
