DLNA Streaming WAV(PCM) files only gives noise
Hello everyone,
I’m trying to get .wav (PCM) files to stream over Plex DLNA. The problem is that I only hear a loud noise.
Flac and mp3 files work fine.
If I play the same files directly from USB or on plex (App and Website) everything works fine as well .
Does anyone know how I can get plex to stream these wav file over DLNA? (without transcoding)
Thanks for your support,
Walter
Yes, there’s problem
