esaad6
December 8, 2021, 2:20am
1
DNLA is not longer working on my Nvidea shield pro. This seems to have happened over the last month or so. Enabling and disabling it does not work either. Has anyone else had similar issue?
I have also noticed that my Plex media server version hasn’t updated in two months.
esaad6:
hasn’t
I have been facing the same issue. DLNA for PMS no longer works on TV or PS4. Please help
Mjc
January 5, 2022, 1:49pm
3
I have this issue as well.
I also have same issue normally use dlna to allow my Yamaha Music System to access ssd attached to Shield 2017. No longer can access my 600 album mp3 album collection. I would go back to older build if i knew where to find them.
Same issue here, latest Plex on a new Shield TV Pro and the DLNA service isn’t running. DLNA logs are empty.
I have found a workaround. I enabled KODI DLNA/UPNP and was able to stream the movies to my LG Smart TV. Just goto Kodi settings, click on services, and then enable the radio buttons under UPNP/DLNA tab.
Are you running Kodi on Nvidia Shield?
Thanks for reports we will look into it.
Yes, I am running Kodi 19.3 on my Nvidia shield pro.
Hello,
Same here since 2 last updates.
Regards,
Damien
Mar 20, 2022 20:47:46.695 [24372] Info — Request: [192.168.1.67:53138 (Subnet)] PUT /:/prefs?DlnaEnabled=1 (14 live) TLS GZIP Signed-in Token (usermail) (Microsoft Edge)
Mar 20, 2022 20:47:46.696 [24372] Attention — [Analytics] Attempting to send unrecognized metric (dlna:settings). Skipping.
Mar 20, 2022 20:47:46.697 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so starting.
Mar 20, 2022 20:47:46.697 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:47:46.697 [7339] Info — Completed: [192.168.1.67:53138] 200 PUT /:/prefs?DlnaEnabled=1 (14 live) TLS GZIP 2ms 320 bytes (pipelined: 3)
Mar 20, 2022 20:47:46.708 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1710 is 2 (failure)
Mar 20, 2022 20:47:46.708 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:47:46.708 [1708] Débogage — [ChildProcessMonitor] attempting to relaunch libPlexDlnaServer.so; attempt number 1, 2 tries remaining
Mar 20, 2022 20:48:06.309 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:48:06.324 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1739 is 2 (failure)
Mar 20, 2022 20:48:06.324 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:48:06.324 [1708] Débogage — [ChildProcessMonitor] attempting to relaunch libPlexDlnaServer.so; attempt number 2, 1 try remaining
Mar 20, 2022 20:48:25.924 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:48:25.937 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1769 is 2 (failure)
Mar 20, 2022 20:48:25.937 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:48:25.937 [1708] Erreur — [ChildProcessMonitor] libPlexDlnaServer.so exited 3 times in less than 60 seconds; giving up.
@bigwheel any update please? Thank you.
I’m sorry I do not have an ETA when this will be fixed. I will poke the bug report
Have you got some news ?
Have a nice day,
esaad6
July 13, 2022, 4:39am
15
Any update on this issue?
Hello,
I cannot find anything new.
Maybe developpers has found something ?
Could it be possible to have an ETA ?
Regards,
