Need help fixing DLNA server / It's gone!
Server Version#: 1.25.3.5410
Hi everyone,
I have my Plex server mounted on a Shield TV, The player and server are the latest version available for the SHield and a few weeks ago I lost the ability to see the DLNA server. My KEF app can no longer see Plex and same with USB Audio Player Pro and my PC. It’s gone from my entire network. I have not done any changes to PLex or my router (that I know of) so it’s pretty strange. I never had problems with that before and I’ve been using PLex (and DLNA) for over 2 years. I have limited knowledge about networking in general but I have read a lot to educate myself hoping to find a solution, but I did not. I restarted the router and plex server many times with no result.
In the console, I have two errors coming back repetitively about every 30sec.
1 error: Error issuing curl_easy_perform(handle): 28
2 error: SSDP: Error parsing device schema for http://169.254.39.244:50755/ed5dc338-0e63-472d-a35f-509c915b2724.xml
Again, I search the net for these two errors and they all seems to point me to my problem, but I don’t know what to do of it. I’ve tried to play with about all settings in PMS web app to see if I had enabled or disabled something by mistake, but can’t see anything wrong. Of course DLNA is checked in th settings. I have no problem to do remote access, just can’t see Plex DLNA server anymore.
Can anyone help?
The 1st error message simply means that a request has timed out. This isn’t necessarily related to DLNA. The 2nd error is linked to Plex’ discovery functionality; certain requests should return an XML response with information about the device (e.g. used by routers or other network based accessories); this particular device sends something else or no XML at all – not linked to DLNA.
Basic DLNA troubleshooting:
  1. “Forced” restart of the DLNA server
    1. Uncheck the DLNA server (Settings > [Server Name] > DLNA > Enable DLNA Server).
    2. Restart the Plex Media Server
    3. Reactivate the DLNA server
  2. Review that your Shield and the other devices are on the same subnet (DLNA doesn’t stream across networks)
Hi Tom,
Thanks for your help, but I already did that with no success.
Any other ideas of what I should try?
Could it be that the ‘‘DLNA Client Preferences’’ is the problem? This is what I have in there: IP=10.0.0.53,DirectPlay=false,DirectStream=false,LocalResolution=320x240,RemoteResolution=320x240,OnlineResolution=320x240,LocalVideoQuality=24,RemoteVideoQuality=24,OnlineVideoQuality=24,SubtitleSize=250,AudioBoost=250,MusicBitrate=320;IP=10.0.0.52,DirectPlay=false,DirectStream=false,LocalResolution=320x240,
This was generated by Plex. I tried to remove it and did not change a thing so I put it back.
Better don’t touch that. This stores a number of client preferences for certain DLNA devices which had been connected before – if you don’t know exactly what you change, the only thing this will cause is bad or broken playback. It’s got nothing to do with your DLNA server showing or not showing up.
Are all those devices on the same subnet inside your home network?
I believe they are but how can I verify that? Sorry but like I said, my knowledge is limited in the matter.
Just as an FYI, I made sure that the device discovery is turned on in my router settings.
Appreciate your help
Hello,
Same problem here.
I think that last update broke everything (since 2 last version).
Everything was working before.
How can we report a bug to the dev team ?
I have uninstall everything, rebuild library from beginning.
All my device are on the same network, local LAN and DLNA server is not seen from any of my client device (PC, amplifier, network sound speaker).
Regards,
Damien
Please find bellow log.
Mar 20, 2022 20:47:46.695 [24372] Info — Request: [192.168.1.67:53138 (Subnet)] PUT /:/prefs?DlnaEnabled=1 (14 live) TLS GZIP Signed-in Token (Usermail) (Microsoft Edge)
Mar 20, 2022 20:47:46.696 [24372] Attention — [Analytics] Attempting to send unrecognized metric (dlna:settings). Skipping.
Mar 20, 2022 20:47:46.697 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so starting.
Mar 20, 2022 20:47:46.697 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:47:46.697 [7339] Info — Completed: [192.168.1.67:53138] 200 PUT /:/prefs?DlnaEnabled=1 (14 live) TLS GZIP 2ms 320 bytes (pipelined: 3)
Mar 20, 2022 20:47:46.708 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1710 is 2 (failure)
Mar 20, 2022 20:47:46.708 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:47:46.708 [1708] Débogage — [ChildProcessMonitor] attempting to relaunch libPlexDlnaServer.so; attempt number 1, 2 tries remaining
Mar 20, 2022 20:48:06.309 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:48:06.324 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1739 is 2 (failure)
Mar 20, 2022 20:48:06.324 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:48:06.324 [1708] Débogage — [ChildProcessMonitor] attempting to relaunch libPlexDlnaServer.so; attempt number 2, 1 try remaining
Mar 20, 2022 20:48:25.924 [1708] Débogage — [ChildProcessMonitor/JobRunner] Job running: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’
Mar 20, 2022 20:48:25.937 [6978] Débogage — Jobs: ‘/data/app/~~6GMdDH7taEKZOgVf1ZS9Iw==/com.plexapp.mediaserver.smb-mEXSJXf7VuO0X9w3VtXcDw==/lib/arm64/libPlexDlnaServer.so’ exit code for process 1769 is 2 (failure)
Mar 20, 2022 20:48:25.937 [1708] Débogage — [ChildProcessMonitor] libPlexDlnaServer.so exited.
Mar 20, 2022 20:48:25.937 [1708] Erreur — [ChildProcessMonitor] libPlexDlnaServer.so exited 3 times in less than 60 seconds; giving up.
The problem seems to be with the Shield TV. I uninstalled PLex and restored the shield to manufacture settings, Reinstalled everything and no change. I also installed a server on my PC and all works fine. So yes, probably an update on the Shield that screwed up something. As much as I like to have the Plex server on the Shield because of its low energy consumption, I’m pretty done with it and will keep my Plex server on my PC.
