aTV3 6.2(6698.99.50.31)
DNS: 192.168.1.147
Local IP: 192.168.1.147
Windows 8 Pro
PMS 0.9.9.18.290-11b7fdd
Local Device PMS: 192.168.147
PlexConnect: Version: 0.4+
DNS: 192.168.1.147
Windows 8 Pro
Did you configure your firewall to allow connection on port 53?
Looks like a cert issue to me I would generate new certs delete the old ones from the aTV and your PC and start over. Is there a reason you are altering the default settings.cfg file? If not just leave settings.cfg default, generate new certs and upload them via network method. Also start with a fresh copy of plexconnect.
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet
@drewbie - Yes
@wahlman - settings were changed because I was trying to find a solution to this problem and used suggestions given to others with the same issue. Should I just leave it default?
As for the cert, I'll try that, and i'll post back. Thanks
Update - Works now! thank you guys so much...
