Server Version#: 1.15.4.994-107756f7e-ls24
Player Version#: web
ive been running plex in docker for months, however the latest update started breaking remote access. i deleted my entire instance and rebuilt it from scratch and while the server is listening on port 32400 i’m unable to find any local servers after i login as a user. i’ve logged out, cleared cache, used different browsers. once i connect to 192.168.1.x/32400/web and select a user it then says no local servers found.
