When setting up the Plex docker on my UNRAID server I’m unable to find the folder where I keep my TVshows at. If I scroll though the box they are not there, but if I log into my server, they sure are there. I posted a couple of screen shots to show you what I mean. I basically want to setup a section called TVshows. And the physically path where the TVshows are on my UNRAID server are
/mnt/user/tvmovies/tvshows
Putting that in the location doesn’t work. Searching with the folder box that pops up doesn’t work either. Check out the screen shots, maybe that will help.
Then here is what the folder is really supposed to look like:
