Server Version#: 1.22.1.4271
Player Version#: Web interface
I have Plex running in a docker container, using the latest image from plexinc/pms-docker. I also run Watchtower, which makes sure I’m always up-to-date on new releases as they are pushed to DockerHub.
Lately I’ve been having issues with Plex, and today I noticed that Metadata Refresh has stopped working, and just flashes the magnifying glass without triggering an actual refresh. In addition, when I now go into the Server options in the web interface, it shows the message “Server settings are unavailable.”
Looking at the Plex container server log, this is what I get:
plex | [fix-attrs.d] applying ownership & permissions fixes...
plex | [fix-attrs.d] done.
plex | [cont-init.d] executing container initialization scripts...
plex | [cont-init.d] 40-plex-first-run: executing...
plex | [cont-init.d] 40-plex-first-run: exited 0.
plex | [cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
plex | [cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
plex | [cont-init.d] 50-plex-update: executing...
plex | [cont-init.d] 50-plex-update: exited 0.
plex | [cont-init.d] done.
plex | [services.d] starting services
plex | [services.d] done.
plex | Starting Plex Media Server.
plex | Plex Plug-in [com.plexapp.system]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [tv.plex.agents.music]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [tv.plex.agents.movie]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.lyricfind]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.themoviedb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.imdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [org.musicbrainz.agents.music]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.opensubtitles]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | /usr/lib/plexmediaserver/Plex Tuner Service: error while loading shared libraries: libcurl.so: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.none]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [tv.plex.agents.series]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.movieposterdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.localmedia]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.htbackdrops]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.lastfm]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.fanarttv]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.thetvdb]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.plexthememusic]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
plex | Plex Plug-in [com.plexapp.agents.subzero]: error while loading shared libraries: libpython2.7.so.1.0: cannot open shared object file: No such file or directory
So, obviously some dependencies are now incorrect in the docker container, compared to what the latest’ish version of Plex Server requires.
I have not yet started a binary search of which release broke the docker container, but y’all (Plex devs) probably have a much better idea.
