Does plex *have* to transcode on local files?
I like using Plex as a lightweight local player keeping track of which episodes I’ve already seen and newly added etc.
However, it isn’t lightweight. Any way to increase performance?
For instance when I play a video on Media Player Classic, it uses like 1% of my CPU. When I play a video on plex, it uses like 7-8, it also lags when I try and skip ahead, or resume. I assume this is because it’s transcoding my files?
Is this normal? Or do I have some kind of setting wrong?
CPU usage will vary according to a wide variety of factors but it’s not something that will stay within a certain range. Can I ask why it matters?
I can’t see any details about which client you are using. There are several, each with its own advantages and disadvantages.
I don’t know what CPU you have but usually the load on the CPU of a non-throttled transcoding session is close to 100%. You can check if the server is transcoding in the web interface to be sure.
Using Plex Media Player for local playback is the better strategy. It requires transcoding much less often than a web browser.
(This is a separate download. You install it additionally to Plex Server.)
