Does plexignore work for music libraries?
Server Version#: 1.31.3.6868
Hello,
In my main music folder, I have a folder I use for importing named:
__import
I want plex to stop auto-scanning this folder every time I’m in there adding/converting files. I would prefer to keep the folder where it is, and named with preceding characters for sorting/workflow reasons.
I have a properly created .plexignore file in my main music folder. It’s on the same level as the other artist folders and the import folder.
It has the following entries:
*__import/*
__import/*
The second line added after the first line didn’t seem to work.
I then added another .plexignore file inside the __import folder with the following entry:
Because at this point, I’m just throwing things at the wall to see if anything works.
Before I start creating a .plexignore file to ignore every possible audio filetype, or experimenting with different folder names, I’m hoping to get feedback on if it’ll even work for a music library or what I’m doing wrong here
Any help would be appreciated. Thanks.
