Dolby Atmos transcoding to OPUS on Apple TV or iOS has no sound
Server Version#: latest
Player Version#: latest
Only way to get sound is to select “use old player” which then converts the sound to AAC.
Why type of Atmos? Share the media info for the files.
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Duration : 2 h 18 min
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 17 s 329 ms
Stream size : 762 MiB (8%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Yeah. This is the supported format. There used to be a thread on Atmos support with Plex player on iOS/tvOS plus spatial audio. It was hit or miss back then and it’s been a while. let me see if I can find it.
Historically support for HDR, Dolby Vision and Atmos has been challenging for a Plex and a lot of work is going on into getting it sorted now. If you’re interested you can join the beta for testing.
This one here. Just to be clear on something else, transcoding of Atmos means you’ll lose the Atmos track regardless if that’s important to your issue, my assumption was you’re actually trying to get the Atmos tracks to pass through.
honestly, just want sound. Atmos support would just be a bonus. I have a Shield to use with my home theatre setup.
