Dolby Vision & Dolby TrueHD Atmos works well on shield tv 2019 with Plex!
Works great :ok_hand: Only PGS Subtitel dosnt work with .ts Files. What we need is this:
Easy way :wink:
Goddamn this is AWESOME! Made an unprotected ISO of Joker (you’ll see why in a sec). Created the MKV with MakeMKV. Opened TSMuxer and dropped the MKV onto it. Opened the mounted ISO’s 800.mpls and added the audio track. Spit out a TS file, dropped it on my NAS. Plex picked it up and is now playing in Dolby Vision with ATMOS. Super brilliant and thanks to all who have been fighting this good fight!!
Dolby Vision support in MKV has been added to the spec! https://github.com/cellar-wg/matroska-specification/pull/390
Dolby Vision support has been added to ExoPlayer! MKV Dolby Vision Support by willtrking Ā· Pull Request #7667 Ā· google/ExoPlayer Ā· GitHub
Your turn Plex! :slight_smile:
Trying to recreate your success making a Plex playable Dolby Atmos and vision video file. What software did you use to make the initial ISO file? Is it a blu-ray ISO? Just need some more info before I can attempt it with my media file(s). I’m rather new at this encoding bit.
For reference, I’ve got what is already labeled as a 2160p 10-bit HDR TrueHD7.1 Atmos movie. When I play it with Plex via Shield using a Sony Atmos receiver and setup it still only shows as TrueHD on the receiver display. When I open it up with MKV tools the audio track does show as 7.1 and is labeled as ā€œAtmosā€. For some reason it isn’t passing through.
Thanks in advance.
The methods discussed here are a bit outdated or old. However, this varies depending on the playback device.
Download Make MKV 1.15.4 - MakeMKV - Download
Here the Beta Key: MakeMKV is free while in beta - www.makemkv.com
Now you need the UHD disc or an ISO, choose the right track, your desired audio tracks and subtitles and let it go. Put this created MKV in your Plex library and play it. Everything works for me, DoVi, Atmos, DTS:X, Subtitles, Chapters, Framerate Switching.
The only thing that some don’t work is when the PGS subtitles have already been pre-selected. You should only select this when the film has started. After that, however, it also works if you continue to watch the film the next day. If the film does not start, the subtitle must be deactivated and then reactivated.
I can’t say why Atmos isn’t working for you. I am not familiar with Sony receivers. Everything is configured correctly and other sources such as Netflix and Co are displaying Atmos correctly?
Try a few Atmos files like this: Core Universe Dolby Trailers - The Digital Theater
