Dolby vision with Dual video tracks in mp4 containers
Hello,
I recently purchased a tcl google tv with Dolby vision and atmos support. I installed the latest plex app from the google play store. Until now I have not been able to play files with the following profile
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom/hev1/dby1)
File size : 69.1 GiB
Duration : 2 h 49 min
Overall bit rate : 58.4 Mb/s
Movie name : Saving Private Ryan
Performer : Steven Spielberg
Performer/Sorted by : Steven Spielberg
Genre : Drama & History & War
Description : As U.S. troops storm the beaches of Normandy, three brothers lie dead on the battlefield, with a fourth trapped behind enemy lines. Ranger captain John Miller and seven men are tasked with penetrating German-held territory and bringing the boy home.
Recorded date : 1998
Encoded date : UTC 2020-02-17 20:24:28
Tagged date : UTC 2020-02-17 20:34:04
Writing application : DVDFab 11.0.7.2
Cover : Yes
Video #1
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 52.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.262
Stream size : 61.7 GiB (89%)
Tagged date : UTC 2020-02-17 20:33:54
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Codec configuration box : hvcC
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 5 798 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.117
Stream size : 6.86 GiB (10%)
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 543 MiB (1%)
Title : English (eac3 5.1)
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Tagged date : UTC 2020-02-17 20:33:55
I’m not sure what I am doing wrong. I was under the impression that plex for google tv was Dolby vision compliant.
Server Version#: 1.24.4.5081
Player Version#: 8.24.1.28493 (2ae123ac)
Welcome to the world of dolby vision profiles.
