I am SO done with our HDHomeRun tuner. We’ve had Plex lifetime for a while and started using the DVR functionality 2-3 years back. It’s had its issues, but the issues have been consistently complicated by the crappiness of this tuner. It comes down to the fact that we have checked the antenna to extreme degrees (even had it worked on by a professional), but we keep losing signal for various channels. Over the last week we’ve lost 2 major channels that we’d had running for years, and no amount of rescans or deleting and re-adding the tuner help. Even going directly to the HDHomeRun software, updating the firmware, and doing a scan from there misses these major channels. However, if I plug the antenna’s coax cable directly into the TV rather than the HDHomeRun, the TV’s internal tuner easily picks up about 20 more channels, including the major networks that keep shutting down through the HDHomeRun!
So I’m thinking we need to replace the dang tuner, and I’m looking for recommendations out of the Plex supported tuners. I will ask for at least 2 tuners in the device, but other than that, I just need it to be able to read signals well and reliably. Am I shooting for the moon here?
Server Version#: 1.23.2.4625
Player Version#: N/A
Tuner Make/Model: HDHomeRun Connect Duo
Guide/Lineup name:
Using XMLTV?: N
Channel number/Name:
