Is there a way to tell Plex to not record a single episode within a series? From everything that I’ve been able to figure out, you can either record the whole series or not record the series. I know there are options to only record on certain channels or SD/HD content.
The exact scenario is I have a series recording set up for Spanish soccer. Currently it’s set up to record every match, but there are certain ones that I don’t care about recording. Do I have to manually select match by match to record, or can I record the series and just remove certain matches?
