Doublons
Server Version#:4.157.0
Hello, I’d like to know why you removed the small squares in the top left corner to indicate that the file is duplicated. This is very useful when you have several movies or series. Will you be putting it back someday?
The duplicates badge went away in March 2021 with Plex Web v4.53.0.
Reference: Plex Web - #348 by chrishoage.
Also, if you just want to find duplicates in your libraries, you can now just apply the “Duplicates” filter in the Library view:
The same is available for TV shows libraries as well, if viewing by episodes:
