Player Version#: 2025.10.2
With Version 8.45 Dovi 5 was working well in MP4 container.
With Version 2025.10.1 is not longer working anymore.
DoVi (Profil 5) colorspace Not supported (Direct Play).
Please fix.
Please fix.
Same on iOS (iPhone). Kills a large portion of my media library. Let’s see if they fix..
I have strange behavior in Wlan.
Everything is playing fine, exept DolbyVision. I get an Error. " A server with the specified hostname could not be found".
This Error is only with Dolby Vision, HDR 10 etc plays fine.
If i turn off wlan and use mobile data, then everything works fine.
What could be the problem ?
No fix or update possible ?
