I just checked and yes you can send it one from one ios device to another. I put the file on my nas and the cloud, in files I long pressed on the ipa, clicked share and airdropped it to my ipad and it installed.
edit: I saved a copy to the phone and that worked as well to send over.
If you have a network share you can place the file on you can mount that from your iPad. Open the Files app, select the ellipsis menu at the top-right, then select âConnect to Server.â The rest is pretty standard.
To copy the file, browse the share, long-press the file in question, then select copy. Then navigate to the destination folder, long-press an open space, and select paste.
Update: I just followed my own instructions again to reinstall plex on my kidâs ipad and everything still works. you might get an alert to update the charles proxy, but you donât need to. you can use the version that direct downloads from the main instructions.
I wanted to download some TV shows for a flight on my kidâs ipad and the new version just downloads all the episodes (50 in this case) with ZERO grouping in the downloads view. it also wonât auto advance to the next episode which is⊠just unbelievable. whoever is in charge of this app really needs to just⊠go away.
**I followed the steps in post 20 and I stumbled (this was 100% a user error). For those of you doing the process on a MAC, these are my simplified steps (at least for me). Took me 3-4 minutes and voila, I have all the features again.
