In these logs, I find:
- A device name PMS doesn’t understand. The names should be generated by Plex apps. Do you recognize this? They occur throughout the logs.
[MetadataAgent/tv.plex.agents.series] [HttpHeader] invalid ‘X-Plex-Device-Name’ header value (Mjölnir)
- Missing directory or damaged filesystem ?
Nov 23, 2024 20:58:07.110 [139723132025656] WARN - Error scanning directory, we’ll skip and continue: boost::filesystem::last_write_time: No such file or directory [system:2]: “/volume1/ARCHIVE/archive1/tv-4k/Arcane”
- Transcode / conversion started then aborted
Nov 23, 2024 20:15:35.809 [139719682063160] DEBUG - [Req#2b6a2a6/Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Nov 23, 2024 20:15:35.809 [139719682063160] DEBUG - [Req#2b6a2a6/Transcode/JobRunner] Job running: EAE_ROOT=/tmp/pms-2dab8fa4-64ea-4b19-af6c-dc44836c3637/EasyAudioEncoder EnableAIL=0 FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/7592546-570471557d92948f58893deb-linux-x86_64/' LIBVA_DRIVERS_PATH="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" NEOReadDebugKeys=1 OCL_ICD_VENDORS="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/cl-icds-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx cl_cache_dir="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Shaders/icr-e8d3b00e629bec95ae9f2c9a-linux-x86_64/" "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:1 truehd_eae -eae_prefix:1 f2df168a1cf06af467904050e617f3e5c1df6bf3_ -analyzeduration 20000000 -probesize 20000000 -i "/volume1/RAID/movies/downloads/completed/radarr/Deadpool 3 ()/Deadpool.and.Wolverine.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR.mkv" -filter_complex "[0:0]hwupload[0];[0]scale_vaapi=w=1920:h=1080:format=p010[1];[1]hwmap=derive_device=opencl[2];[2]tonemap_opencl=tonemap=hable:format=nv12:m=bt709:p=bt709:r=tv[3];[3]hwmap=derive_device=vaapi:reverse=1[4];[4]hwupload[5]" -map "[5]" -codec:0 h264_vaapi -b:0 5325k -maxrate:0 7100k -bufsize:0 14200k -r:0 23.975999999999999 -filter_complex "[0:1] aresample=async=1:ochl='7.1':rematrix_maxval=0.000000dB:osr=48000[6]" -map "[6]" -metadata:s:1 language=eng -codec:1 libopus -b:1 424k -map 0:4 -metadata:s:2 language=eng -codec:2 ass -strict_ts:2 0 -f matroska -map_metadata -1 -map_chapters -1 Output.mkv -init_hw_device vaapi=vaapi:/dev/dri/renderD128,driver=iHD -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress
Nov 23, 2024 20:15:35.809 [139719682063160] DEBUG - [Req#2b6a2a6/Transcode/JobRunner] In directory: "/dev/shm/Transcode/Sessions/plex-transcode-f2df168a1cf06af467904050e617f3e5c1df6bf3-9b619885-2b43-4898-a753-22afd8b4ed6f"
Nov 23, 2024 20:15:35.809 [139719682063160] DEBUG - [Req#2b6a2a6/Transcode/JobRunner] Jobs: Starting child process with pid 1790777
Nov 23, 2024 20:15:35.810 [139719483222840] DEBUG - [Req#2b6a2a6/Transcode] Whacked session 457471c72b9262b58fddcc8ce9539cae67a8e1bc, 3 remaining.
Nov 23, 2024 20:15:35.811 [139719662820152] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=startup (16 live) #2b6a2a4 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.811 [139723157338936] DEBUG - Completed: [127.0.0.1:50914] 204 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=startup (16 live) #2b6a2a4 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Nov 23, 2024 20:15:35.815 [139719474797368] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=startup (16 live) #2b6a2b9 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.815 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 204 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=startup (16 live) #2b6a2b9 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Nov 23, 2024 20:15:35.815 [139719421299512] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=opening (16 live) #2b6a2ba Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.815 [139723157338936] DEBUG - Completed: [127.0.0.1:50914] 204 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=opening (16 live) #2b6a2ba 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139719662820152] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=opened (16 live) #2b6a2bb Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 204 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress?status=opened (16 live) #2b6a2bb 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139719474797368] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=0&id=0&codec=hevc&type=video (16 live) #2b6a2bc Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 200 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=0&id=0&codec=hevc&type=video (16 live) #2b6a2bc 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139719421299512] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=1&id=0&codec=truehd&type=audio (16 live) #2b6a2bd Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.817 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 200 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=1&id=0&codec=truehd&type=audio (16 live) #2b6a2bd 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Nov 23, 2024 20:15:35.818 [139719662820152] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=2&id=0&codec=ac3&type=audio (16 live) #2b6a2be Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.818 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 200 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=2&id=0&codec=ac3&type=audio (16 live) #2b6a2be 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Nov 23, 2024 20:15:35.818 [139719474797368] DEBUG - Request: [127.0.0.1:50914 (Loopback)] PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=3&id=0&codec=ac3&type=audio (16 live) #2b6a2bf Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:15:35.818 [139723159448376] DEBUG - Completed: [127.0.0.1:50914] 200 PUT /video/:/transcode/session/f2df168a1cf06af467904050e617f3e5c1df6bf3/9b619885-2b43-4898-a753-22afd8b4ed6f/progress/stream?index=3&id=0&codec=ac3&type=audio (16 live) #2b6a2bf 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Nov 23, 2024 20:15:35.832 [139723169917752] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 1790402 is -9 (signal: Killed)
- The next transcode starts and is aborted
Nov 23, 2024 20:16:09.080 [139719421299512] DEBUG - [Req#2b6a3ff/Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Nov 23, 2024 20:16:09.080 [139719421299512] DEBUG - [Req#2b6a3ff/Transcode/JobRunner] Job running: EnableAIL=0 FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/7592546-570471557d92948f58893deb-linux-x86_64/' LIBVA_DRIVERS_PATH="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" NEOReadDebugKeys=1 OCL_ICD_VENDORS="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/cl-icds-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx cl_cache_dir="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Shaders/icr-e8d3b00e629bec95ae9f2c9a-linux-x86_64/" "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:1 dca -analyzeduration 20000000 -probesize 20000000 -i "/volume1/ARCHIVE/archive1/radarr/Predator (1987)/Predator (1987).mkv" -filter_complex "[0:0]hwupload[0];[0]scale_vaapi=w=1920:h=1080:format=p010[1];[1]hwmap=derive_device=opencl[2];[2]tonemap_opencl=tonemap=hable:format=nv12:m=bt709:p=bt709:r=tv[3];[3]hwmap=derive_device=vaapi:reverse=1[4];[4]hwupload[5]" -map "[5]" -metadata:s:0 language=eng -codec:0 h264_vaapi -b:0 5434k -maxrate:0 7246k -bufsize:0 14492k -r:0 23.975999999999999 -filter_complex "[0:1] aresample=async=1:ochl='5.1':rematrix_maxval=0.000000dB:osr=48000[6]" -map "[6]" -metadata:s:1 language=eng -codec:1 libopus -b:1 321k -f matroska -map_metadata -1 -map_chapters -1 Output.mkv -init_hw_device vaapi=vaapi:/dev/dri/renderD128,driver=iHD -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress
Nov 23, 2024 20:16:09.080 [139719421299512] DEBUG - [Req#2b6a3ff/Transcode/JobRunner] In directory: "/dev/shm/Transcode/Sessions/plex-transcode-457471c72b9262b58fddcc8ce9539cae67a8e1bc-28945fd5-5d43-4394-b035-27a1d474a98a"
Nov 23, 2024 20:16:09.080 [139719421299512] DEBUG - [Req#2b6a3ff/Transcode/JobRunner] Jobs: Starting child process with pid 1790811
Nov 23, 2024 20:16:09.082 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=startup (15 live) #2b6a3fd Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.082 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 204 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=startup (15 live) #2b6a3fd 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Nov 23, 2024 20:16:09.086 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=startup (14 live) #2b6a412 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.086 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 204 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=startup (14 live) #2b6a412 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Nov 23, 2024 20:16:09.086 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=opening (14 live) #2b6a414 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.086 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 204 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=opening (14 live) #2b6a414 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Nov 23, 2024 20:16:09.087 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=opened (14 live) #2b6a415 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.087 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 204 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress?status=opened (14 live) #2b6a415 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Nov 23, 2024 20:16:09.087 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=0&id=0&codec=hevc&type=video (14 live) #2b6a416 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=0&id=0&codec=hevc&type=video (14 live) #2b6a416 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=1&id=0&codec=dts&type=audio (14 live) #2b6a417 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=1&id=0&codec=dts&type=audio (14 live) #2b6a417 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=2&id=0&codec=dts&type=audio (14 live) #2b6a418 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=2&id=0&codec=dts&type=audio (14 live) #2b6a418 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=3&id=0&codec=dts&type=audio (14 live) #2b6a419 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=3&id=0&codec=dts&type=audio (14 live) #2b6a419 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=4&id=0&codec=dts&type=audio (14 live) #2b6a41a Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=4&id=0&codec=dts&type=audio (14 live) #2b6a41a 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=5&id=0&codec=ac3&type=audio (14 live) #2b6a41b Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=5&id=0&codec=ac3&type=audio (14 live) #2b6a41b 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=6&id=0&codec=dts&type=audio (14 live) #2b6a41c Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=6&id=0&codec=dts&type=audio (14 live) #2b6a41c 0ms 195 bytes (pipelined: 11) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=7&id=0&codec=dts&type=audio (14 live) #2b6a41d Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=7&id=0&codec=dts&type=audio (14 live) #2b6a41d 0ms 195 bytes (pipelined: 12) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=8&id=0&codec=dts&type=audio (14 live) #2b6a41e Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.088 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=8&id=0&codec=dts&type=audio (14 live) #2b6a41e 0ms 195 bytes (pipelined: 13) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=9&id=0&codec=dts&type=audio (14 live) #2b6a41f Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=9&id=0&codec=dts&type=audio (14 live) #2b6a41f 0ms 195 bytes (pipelined: 14) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=10&id=0&codec=ac3&type=audio (14 live) #2b6a420 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=10&id=0&codec=ac3&type=audio (14 live) #2b6a420 0ms 195 bytes (pipelined: 15) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=11&id=0&codec=ac3&type=audio (14 live) #2b6a421 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=11&id=0&codec=ac3&type=audio (14 live) #2b6a421 0ms 195 bytes (pipelined: 16) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719682063160] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=12&id=0&codec=dts&type=audio (14 live) #2b6a422 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=12&id=0&codec=dts&type=audio (14 live) #2b6a422 0ms 195 bytes (pipelined: 17) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719662820152] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=13&id=0&codec=dts&type=audio (14 live) #2b6a423 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723159448376] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=13&id=0&codec=dts&type=audio (14 live) #2b6a423 0ms 195 bytes (pipelined: 18) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139719474797368] DEBUG - Request: [127.0.0.1:50916 (Loopback)] PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=14&id=0&codec=ac3&type=audio (14 live) #2b6a424 Signed-in Token (PappaVanWinkle) (range: bytes=0-)
Nov 23, 2024 20:16:09.089 [139723157338936] DEBUG - Completed: [127.0.0.1:50916] 200 PUT /video/:/transcode/session/457471c72b9262b58fddcc8ce9539cae67a8e1bc/28945fd5-5d43-4394-b035-27a1d474a98a/progress/stream?index=14&id=0&codec=ac3&type=audio (14 live) #2b6a424 0ms 195 bytes (pipelined: 19) (range: bytes=0-)
Nov 23, 2024 20:16:09.091 [139723169917752] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 1790465 is -9 (signal: Killed)
Nov 23, 2024 20:16:09.091 [139719589018424] DEBUG - Cleaning directory for session 2b276e219f48d9fbeedc907841f59518adb007de (/dev/shm/Transcode/Sessions/plex-transcode-2b276e219f48d9fbeedc907841f59518adb007de-e63f72ca-7b4f-4a1b-87d1-a87a5971b676)
Is this when the failure occurred ?
There is nothing in your logs which report any errors.
I only see this activity report.
Are the player devices out of memory for download?
