Plex player on Android (Google Pixel 6a) downloads screen is buggy. It doesn’t show the top line, no way to resume downloads.
Server Version#:
The app has always had issues dealing with the devices zoom level. Set it lower temporarily so you can get to the button.
Thanks for report. If you change the sort menu from “downloaded at” to “Title” or “Size” does it move the pause button over?
Yup. Looks like that works too.
Yes, that change makes it work. Awkward anyway. But at least it works. Thanks.
