DR and TV2 plugins (Denmark)
sorry it was installed by default, my bad :)
Live streams also not working here. It just keeps buffering and I have to quit plex.
Nope. I'm using Plex 8 myself.
Don't know if the P in plug-ins needs to be capital. It is in my path.
This is simply amazing. Recently I was looking for an old TV mini series called "Dybt Vand" - which I couldn't find, but now I can watch it through Bonanza. Also the old 80 comedy shows are great to see again.
Actually it seems the video quality is better in Plex compared to the fullscreen player on dr.dk?
Thanks for extreme awesomeness!
excellent plugins, much appriciated!
prøv evt. at tage et kig på
http://www.dr.dk/pirattv/
at kunne få adgang til alt dette fra plex ville være fantastisk!! :slight_smile:
Hmm. I can’t seem to get the DR plugin to work.
It’s installed in %username/Library/Application Support/Plex Media Server/Plug-ins … but no luck. Once it’s in that folder is there something I need to do to activate it? In which menu am I supposed to find it?
*/mertz
Version 0.4 is up on http://wiki.plexapp.com/index.php/DR
* Changed live streams to use flash based streams - better stability and audio sync
* Added live streams for DR Update, DR K, and DR Ramasjang
Du får et lidt sent svar, men jeg troede ikke det var muligt første gang jeg kiggede på det, da det hele kører i en stor flash fil. Men jeg kiggede lige på det igen, og det er muligt at hive de enkle videoklip ud og vise i en afspiller. Der går nok nogle uger før jeg får tid til at lave det, da jeg er ved at integrere DR's on-demand tv. Det har højere prioritet.
It should work right away. Have you tried again?
Version 0.5 http://wiki.plexapp.com/index.php/DR
* Added support for On Demand TV
* Changed Livestreams to use internal silverlight player instead of external silverlight player
NB: Requires Silverlight installed to use On Demand TV. Browse to http://www.plexapp.com/player/silverlight.php in Safari - a “Download Silverlight” button should appear if it is not installed
This is awsome, thank you very much…
Now all we need is a Sputnik plugin :slight_smile:
Version 0.6 http://wiki.plexapp.com/index.php/DR
* Added Radio channels
Nikki, great work, but do you mind adding some sort of image when playing radio? not very nice to have a black screen… :slight_smile:
/mkh
Not sure that is possible, as I am using the silverlight video player :frowning:
Oh, mkay, maby you can add an image when radio is playing, not one for each station, just something like in EteTV Hybrid? if you know that
Wich looks like this -> [EyeTV Radio](http://support.elgato.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=3244)
Super! Har brugt plugin’et siden det understøttede Bonanza, men nu lader det jo til at være blevet lige det Plex mangler - dansk live/on-demand TV
Den dag det er muligt at bruge sputnik, ja så kan jeg vidst godt opsige alle mine fine TV pakker..
Version 0.7 http://wiki.plexapp.com/index.php/DR
* Fixed Bonzanza Radio
* Improved Bonanza handling of collections (series)
* Added backup streams of Live TV
Still not possible. Since I use the Silverlight video player to play the audio streams, I'd have to transcode the stream realtime to a video stream and embed the picture. Unless of course the Plex team adds a feature to the silverlight player, so it is possible to show a picture.
Har kigget lidt på Sputnik... Kan ikke afspille deres streams i Silverlight afspilleren :( Muligvis er det fordi det er DRM streams som den ikke kan afspille.
